Redirect stdout to LPUART when using S32K14 SDK instead of EWL?
1,365 次查看
satish_k_singh
Hello ,
Currently I am working with the S32K148 eval board , and making use of the available Printf function for printing the debug information on the PC terminal.
Could you please let know or share some info if it  is possible to redirect stdout to LPUART when using S32K14 SDK instead of EWL?
标记 (4)
1,237 次查看
jiri_kral
here is example for using printf/scanf via LPUART -
 https://community.nxp.com/docs/DOC-335240
It is for S32K144 - but the principle is same.
Hope it helps.
Jiri
