JTAG with S32k148 evb
2,101 次查看
richard_clouse
I am using OpenSDA to program an s32k148 chip on the s32k148 evb. I need to switch to jtag. Can anyone help by suggesting an adaptor, cable, debugger and software? So far I'm seeing Segger and jlink. There are a lot of options. Can someone point me to a list of what I need please?
标记 (4)
1 回复
1,924 次查看
jiri_kral
You can use segger j-link, PE Micro Multilink FX (or other version supporting ARM) or Lauterbach. With PE Micro you can use the same debug configuration as for OpenSDA.
MULTILINK FX | Advanced High Performance Debug Probe | PEmicro
Jiri
