Procedure import peripheral configuration files from Project 1(FreeRTOS)-> Project 2 (Bare-metal)
已解决
跳至解决方案
2,679 次查看
bhanurajesh_bha
HI Experts,
We created a project using S32D Design Studio.
Project 1 : ECU with S32K116 Micro & FreeRTOS.
Project 2 : same ECU but Bare-metal (No FreeRTOS).
Could you please help anyway to import peripheral configuration files from Project 1(FreeRTOS)-> Project 2 (Bare-metal)
Thanks in Advance,
BBR
标记 (4)
1 解答
2,612 次查看
jiri_kral
I'm not sure what is your goal - in my opinion easiest way is just remove FreeRTOS SDK component from your existing project and move your code from FreeRTOS tasks. Or what's your issue?
Jiri
在原帖中查看解决方案
2 回复数
2,613 次查看
jiri_kral
Jiri
2,612 次查看
bhanurajesh_bha
Thank you very much.
