Does the S32DS Real Time Expressions tool support JLINK
gongchangyu
 am using Multilink and OpenSDA to check the value of the variable through the Real Time Expressions tool. It is not successful to use JLINK here. Please help to confirm whether the plug-in function supports the JLINK debugging tool. Thank you
jiri_kral
as far as I know, real time expressions is part of PE Micro plugin and is not supported by Segger J-Link.
Jiri
gongchangyu
ok,thanks for your answer.
