Problem entering debugging mode, gdb server was unable to start.
2,856件の閲覧回数
froike
When I try enter debugging mode in "S32 Design Studio 2018" (Linux 64, Ubuntu 16.04.3) an error popup tells me that:
Error in services launch sequence
There appears to be an issue with your network settings.
The gdb server was unable to start a required server component.Please contact technical support.
Anyone know the case or can help me?
Roi.
  • Add to Phrasebook
    • No wordlists for English -> Hebrew...
    • Create a new wordlist...
  • Copy
  • Add to Phrasebook
  • Copy
  • Add to Phrasebook
  • Copy
3 返答(返信)
2,575件の閲覧回数
jiri_kral
Hi Roi,
there is probably missing ncurses5 32 bit library on your machine. Please check with ldd command if all libraries for gdb are present:
ldd [YOUR_S32DS_INSTALL_PATH]/Cross_Tools/gcc-arm-none-eabi-4_9/bin/arm-none-eabi-gdb
Jiri
2,575件の閲覧回数
froike
I have all this libraries:
ldd ~/.NXP/S32DS_ARM_v2018.R1/Cross_Tools/gcc-arm-none-eabi-4_9/bin/arm-none-eabi-gdb
    linux-gate.so.1 =>  (0xf7fcb000)
    libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xf7f9d000)
    libncurses.so.5 => /lib/i386-linux-gnu/libncurses.so.5 (0xf7f77000)
    libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf7f22000)
    libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf7d6c000)
    /lib/ld-linux.so.2 (0xf7fcd000)
    libtinfo.so.5 => /lib/i386-linux-gnu/libtinfo.so.5 (0xf7d48000)
But problem still there
2,575件の閲覧回数
jiri_kral
So, are you able run standalone gdb server from console?
Can you please share console debug session output?
Jiri
