PEmicro SWO Printf Debug by S32 Design Studio for ARM(S32K148)
shijie_zheng
Hi :
I want use PEmicro SWO Printf function,but I can't find SWO configuration in “S32 Design Studio for ARM ver2.2”.
I have open SWO Printf window,and add printf() in project,but SWO Printf window keep none when debugging.
Is anyone used SWO function? Please give me an example,thank you.
shijie_zheng
Dear danielmartynek :
Thank you for your reply,i have check my board,unfortunately,SWO is not supported.
I'm going to use the UART channel to output the log.
danielmartynek
The S32K148 MCU supports SWO.
I haven't used it with S32DS though.
shijie_zheng
Hi danielmartynek :
The board that I'm using now, the TDO port is not connected,I will try to pull out the TDO port and test it again.
