PEmicro SWO Printf Debug by S32 Design Studio for ARM(S32K148)
4,898 次查看
shijie_zheng
Hi :
I want use PEmicro SWO Printf function,but I can't find SWO configuration in “S32 Design Studio for ARM ver2.2”.
I have open SWO Printf window,and add printf() in project,but SWO Printf window keep none when debugging.
Is anyone used SWO function? Please give me an example,thank you.
4 回复数
4,880 次查看
shijie_zheng
Dear danielmartynek :
Thank you for your reply,i have check my board,unfortunately,SWO is not supported.
I'm going to use the UART channel to output the log.
4,865 次查看
danielmartynek
The S32K148 MCU supports SWO.
I haven't used it with S32DS though.
4,852 次查看
shijie_zheng
Hi danielmartynek :
The board that I'm using now, the TDO port is not connected,I will try to pull out the TDO port and test it again.
