PEMicro which version supporting S32K358
已解决
跳至解决方案
3,104 次查看
LeoZ
When I use PEMicro to link to my S3258 board, I got bellow issue "This hardware interface is an older model and does not support this device"
* does this mean my PEMicro version is too low?
* my PEMircro version is shown as bellow, does the 'Rev A' not support S32K358 and I should purchase a new version, and which version ?
1 解答
3,083 次查看
Mehul_Patel_NXP
Hi, @LeoZ ,
The PE multilink debugger you are using does not support S32K258 series.
You will require to use PEMicro Multilink FX.
Please check PE Micro website for more information for supported version, and hardware series.
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=5046
https://www.pemicro.com/arm/device_support/NXP_Automotive/index.cfm
Thank you. Best regards.
- Mehul Patel
在原帖中查看解决方案
2 回复数
3,084 次查看
Mehul_Patel_NXP
Hi, @LeoZ ,
- Mehul Patel
3,059 次查看
LeoZ
I purchased Multilink Rev.E, which solved this problem
