New Project Wizard Has No Processors to select from.
6,833件の閲覧回数
brian_flinn
Hello:  I am trying to follow HOWTO: Add a new debugger configuration to an existing project .
The first issue is in "b.  New Project Wizard, processor and toolchain page.  I have no selections available ??
See attached.
Can anyone help me fix this?
Brian
タグ(2)
8 返答(返信)
6,581件の閲覧回数
brian_flinn
I see that S32 DS for ARM 2018.R1 apparently does not ?
If not, what are the recommended Debug Probes ?
Brian
6,581件の閲覧回数
jiri_kral
S32DS by default supports PE Micro and Segger j-link probes. PE Micro Multilink FX is good choice - if you like to use extarnal probe. Most of S32K1xx EVB has integrated PE Micro Open SDA debug probe.
Jiri
6,581件の閲覧回数
brian_flinn
Hello:
Does S32 DS for ARM 2018.R1 support S32 Debug Probe ?
6,581件の閲覧回数
brian_flinn
Hello:
S32DS version is V3.2,  target is S32K142
Brian
6,581件の閲覧回数
jiri_kral
you need to install different version of S32DS - S32 Design Studio for ARM 2018.R1 (Windows/Linux) released!
Here are details about S32DS Versions:
https://community.nxp.com/docs/DOC-335338
Hope it helps.
Jiri
6,582件の閲覧回数
brian_flinn
Hello:
What Debug Probe(s) are recommended, (specific models etc.) are recommended for use with - S32 Design Studio for ARM 2018.R1 and S32K142 ?
Brian
6,581件の閲覧回数
jiri_kral
what's your S32DS Version and what is your target MCU?
Jiri
6,581件の閲覧回数
brian_flinn
Hello:
<what's your S32DS Version and what is your target MCU?>
S32DS Version is V3.2, Target is S32K142
Brian
