Missing License for S32DS 3.4 - CLLReason [errorNo = 21 ......]
5,138 次查看
ajayyadav1996
I was using S32DS Version 3.4 and suddenly it was stopped working and a pop up message came up for "Missing License".
I have license activation key and I used it for online as well as offline activation but following error message is coming :
CLLReason [errorNo=21,errorString= Error sending an activation request to remote activation server and processing the resulting respone.........]. Please see attachment.
Can you please help me with this.
Ajay
4,225 次查看
Mehul_Patel_NXP
Hi, Ajay,
As I talked with you, it has found that it was firewall setting which was blocking the server request for the license activation.
Happy that you were able to resolve the issue and move forward.
Thank you, Best regards,
- Mehul
5 回复数
4,226 次查看
Mehul_Patel_NXP
Hi, Ajay,
- Mehul
4,217 次查看
ajayyadav1996
Hello Mehul,
Yes, It worked with this solution. Thank you
BR,
Ajay
4,996 次查看
Mehul_Patel_NXP
Hi, @ajayyadav1996,  I see there is another thread regarding the issue.
Is this problem solved, please can you update on the issue.
Thank you, Kind regards.
- Mehul Patel
5,102 次查看
Mehul_Patel_NXP
Hi, Ajay,
Please can you provide activation code you are using for installation of the particular version of Design Studio.
Please can you also provide workspace log, Design studio Installation log.
You can find workspace log at
C:\Users\Public\[workspace name]\.metadata
You can find S32DS installation  log at:
C:\NXP\S32DS.3.5\[_S32 Design Studio for S32 Platform 3.4_installation- something like this] \Logs
Thank you. Best regards.
- Mehul
5,066 次查看
ajayyadav1996
Hello Mehul,
Thanks a lot for your response. Here I have attached logs, metadata and activation key I have sent you on private message.
Ajay
