MPC5744 Debug error
MPC5744 Debug error
2,699 次查看
dsytj88
Version:S32 v1.2
after flashing the file into MCU.I tried to use debug mode to lauch MPC5744P.elf file,
in the progress it will be blocked,and error box appeared:
Error with command: gdb --version
Cannot run program "gdb": Launching failed
I tried another demo and it shows the same problem,do you know what's the reason and how to resolve it?
thank you
标记 (4)
2,177 次查看
stanish
Could you possibly check if the debug configuration is complete.
I'd also recommend you to try to create a new workspace in  v1.2 and import your project.
Hope it helps.
Stan
