In CW v11, it can be created project with PEx(processor expert) for KEA but it can't be in S32DS. I created a project with KEAZN64 sdk, but it can't be used PEx. Could you guide about how to use PEx for KEA?
Should I use CW v11 only? Or create and use the project with PEx in CW v11 and then it can be imported to S32DS?
Also, can I get an example code with PEx for KEA?
FYI, I'm using KEAZN16.
Kate Lee
