Install new SW in S32DS
21,885 次查看
koehlerl
I get this error
It worked in former times. What is my Problem now. I think it has to do with the JRE.
BR Lutz
标记 (3)
21,330 次查看
koehlerl
now it works, it was a problem with the firewall.
Lutz
Von: jiri.kral@nxp.com
Gesendet: Mittwoch, 28. November 2018 11:30
An: Köhler, Lutz <lutz.koehler@acd-antriebstechnik.de>
Betreff: Re: - Re: Install new SW in S32DS
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
reply from Jiri Kral<https://community.nxp.com/people/jiri.kral@nxp.com?et=watches.email.thread> in S32 Design Studio - View the full discussion<https://community.nxp.com/message/1085301?commentID=1085301&et=watches.email.thread#comment-1085301>
11 回复数
21,329 次查看
mikedoidge
Hello koehlerl‌,
Try to attach the error message again.
Mike
21,327 次查看
koehlerl
Hi Jiri,
I can’t select the eroor log window under Window > Show View.
The Error Log view captures all the warnings and errors logged by plug-ins.
It is not possible in the S32DS Version to show this window ?
Lutz
Von: mikedoidge
Gesendet: Dienstag, 27. November 2018 19:30
reply from Mike Doidge<https://community.nxp.com/people/mikedoidge?et=watches.email.thread> in S32 Design Studio - View the full discussion<https://community.nxp.com/message/1084920?commentID=1084920&et=watches.email.thread#comment-1084920>
21,327 次查看
jiri_kral
looks that there is no such view in S32DS. The log file is located .metadata directory in your workspace:
Jiri
21,325 次查看
koehlerl
I get the error message again.
Von: Mike Doidge
Betreff: You have been mentioned by Mike Doidge in Re: Install new SW in S32DS in NXP Community
by Mike Doidge<https://community.nxp.com/people/mikedoidge?et=notification.mention> in Re: Install new SW in S32DS in NXP Community - View Mike Doidge's reference to you<https://community.nxp.com/message/1084920?commentID=1084920&et=notification.mention#comment-1084920>
21,325 次查看
jiri_kral
Hi Lutz,
Did you try use default PE Micro updates link - http://www.pemicro.com/eclipse/updates   instead of your specific one? It looks that your site is not reachable.
Jiri
21,322 次查看
koehlerl
HI Jiri,
I want to install Linticator - http://linticator.com/update/v0/
I get the same error message. It is a problem with the Java Version ?
Lutz
Gesendet: Mittwoch, 28. November 2018 07:58
reply from Jiri Kral<https://community.nxp.com/people/jiri.kral@nxp.com?et=watches.email.thread> in S32 Design Studio - View the full discussion<https://community.nxp.com/message/1085057?commentID=1085057&et=watches.email.thread#comment-1085057>
21,321 次查看
jiri_kral
I just install it - and no issue:
Is your internet connection working okay? I have default S32DS installation:
So - you can try to re-install your S32DS.
Jiri
21,322 次查看
koehlerl
in my log file is this entry:
!SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2018-11-28 11:07:36.482
!MESSAGE HTTP Server 'Internal Error': http://linticator.com/update/v0/content.jar
!STACK 1
org.eclipse.ecf.filetransfer.IncomingFileTransferException: HttpComponents connection error response code 500.
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:667)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:885)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:428)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:360)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:402)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:259)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:440)
at org.eclipse.equinox.internal.p2.ui.QueryableMetadataRepositoryManager.doLoadRepository(QueryableMetadataRepositoryManager.java:46)
at org.eclipse.equinox.internal.p2.ui.QueryableMetadataRepositoryManager.doLoadRepository(QueryableMetadataRepositoryManager.java:1)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.loadRepository(QueryableRepositoryManager.java:120)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.query(QueryableRepositoryManager.java:157)
at org.eclipse.equinox.internal.p2.ui.QueryableRepositoryManager.query(QueryableRepositoryManager.java:72)
at org.eclipse.equinox.internal.p2.ui.ElementQueryDescriptor.performQuery(ElementQueryDescriptor.java:60)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:104)
at org.eclipse.equinox.internal.p2.ui.model.CategoryElement.fetchChildren(CategoryElement.java:125)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:37)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:231)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!SUBENTRY 2 org.eclipse.ecf.identity 4 0 2018-11-28 11:07:36.482
!MESSAGE HttpComponents connection error response code 500.
Gesendet: Mittwoch, 28. November 2018 10:43
reply from Jiri Kral<https://community.nxp.com/people/jiri.kral@nxp.com?et=watches.email.thread> in S32 Design Studio - View the full discussion<https://community.nxp.com/message/1085218?commentID=1085218&et=watches.email.thread#comment-1085218>
21,322 次查看
jiri_kral
in my opinion there is some issue with your network/firewall settings.
Jiri
21,331 次查看
koehlerl
Lutz
21,320 次查看
koehlerl
I had the same issue, but our admin checked this, and he told me there is nothing blocking.
Lutz
