ICC-LINUX-CAN
ICC-LINUX-CAN
2,132 次查看
frank_feng
I totally have two questions about S32V234 .
One is how to flash the M4 code using S32DS and where the code would be stored to ?
Another one is that I need a demo which is used for inter core communication between M4 running on bareboard and A53 running on linux ,it's looks pretty much like following picture shows :
Any information related is needed for sure.
2,030 次查看
447825937
HI,
Have you find any solution about that ?
appreciate if you can share it .
Thx!
