I get an error when I open the project folder.
1,095 次查看
michelangeliousas
I was using version 3.4 of the S32 Design studio IDE. But I changed my computer and installed version 3.5. When I open every project folder I import, the IDE directly gives an error. There is no problem in compiling, but I get the following error;
"Current version of the toolchain is no longer supported. It is necessary to perform project migration to a later version."
As a result of this process, should I reinstall the old version IDE from scratch? Or is there another solution?
1,049 次查看
Miguel04
Hi @michelangeliousas
Your issue seems to be the compatibility of the IDE version and the packages installed.
Reinstalling the old version could be a solution, however if you can share with me the packages you use I can verify if there are available for the 3.5 version of S32 Design Studio.
Please let me know.
