I cant run or debug example projects for s32k144
1,452件の閲覧回数
vinaykl
When I try to run example project for s32k144 it is giving some errors. Actually it is building , but not debugging or running. It is giving some errors
"Error with command: gdb --version
Cannot run program "gdb": Launching failed"
1,446件の閲覧回数
KalaimaniArumugamdev
Hi @vinaykl
    This issue because of configuration, go to debug configuration window delete previous configuration and create new"GDB PEMicro interface configuration" and select your target file. And click debug button .
 If it is not working check your programmer connection with target and power source
