How to use S32FlashToll?
Zzzz1
Help:
I wanted to burn the code to the emmc/flash using S32FlashTool, but I encountered the following problem:
My S32FlashTool version is 2.1.7, my board is S32G-VNP-RDB2. And I confirmed that there are relevant bin files in the installation folder of Flashtool. But why did the initialization algorithm fail?
Thank you very much!
Joey_z
hi,Zzzz1
Thank you for your information.
You can try to change the switch of SW3 to OFF.
Joey
Joey_z
hi,Zzzz1
Joey
Zzzz1
