How to show Runtime in S32K FreeRTOS
2,701件の閲覧回数
jianlongzhang
Hi All,
I see there is a TaskList indicator show task's information. But I cannot see RunTime view, even after check the "Collect runtime statistics". Do you know how to see the runtime statistics? Is there any special configuration to do? Thank you.
Best Regards
Tony Zhang
タグ(3)
2 返答(返信)
2,513件の閲覧回数
ovidiualexandru
Hi Tony, Jiri,
Currently I can recommend a workaround to get the Runtime facility working:
In the FreeRTOS component, go to the 'User Settings' tab and add a definition (click on the three dots):
#define portREMOVE_STATIC_QUALIFIER 1
like in this snapshot:
After, re-generate Processor Expert code.
Now the 'Runtime' facility should work as expected:
Ovidiu
2,513件の閲覧回数
jiri_kral
Hi Tony,
I can confirm the same behavior. No Runtime stat with enabled requested macros. I sent this thread into SDK team, hope someone will ask it soon.
Jiri
