How to reset LIN STACK
已解决
跳至解决方案
2,670 次查看
RickYeh777
Dear Sir,
  I am working on a project on S32SDK and LIN STACK, which is adopted from lin_slave_s32k118.
And after some intentional/abnormal operations, LIN STACK fell into the below situation.
tl_desc_ptr->tx_msg_status = LD_N_AS_TIMEOUT;
tl_desc_ptr->check_timeout_type = LD_NO_CHECK_TIMEOUT;
ld_send_message() was blocked by the check statement.
Should I reset LIN STACK? and How to reset LIN STACK?
Thanks for your help a lot.
1 解答
2,655 次查看
RickYeh777
Just call ld_init() at the proper position.
在原帖中查看解决方案
标记 (1)
1 回复
2,656 次查看
RickYeh777
标记 (1)
