How to re-install S32DS?
已解决
跳至解决方案
2,746 次查看
Byungju
Dear NXP,
I try to re-install S32DS because my WIN OS is broken.
But after entering activation code, following error message is poped-up.
So I try to return license. But It is not allowed.
Would you please help let me know how to re-install S32DS?
Thanks and best regards,
标记 (2)
1 解答
2,729 次查看
mikedoidge
Hello @Byungju,
I checked your account, I can see you have only 1 license for S32DS 3.5 under the activation code which ends with 'F3F7'. It was still assigned to your previous Windows OS so that is why you received this message. I have returned the license from within the server, so this should now be resolved.
I also noticed you have another activation code on your account for S32DS 3.5 which contains 101 licenses. This code ends with '3250'. I would suggest that you use this one since it contains many more licenses and you wouldn't likely face this issue again.
Mike
在原帖中查看解决方案
2 回复数
2,730 次查看
mikedoidge
Hello @Byungju,
Mike
2,722 次查看
Byungju
Dear Mikedoidge,
Reinstalling S32DS is success.
Thank you for your great support.
