How to create a function combined by C and assembler language in S32DS?
已解决
跳至解决方案
2,648 次查看
446018332
Hi,Support
I am using S32DS to create a function combined by C and assembler language which is copied from your official net. This project is used in MPC5643L. But it has a problem when I tried to build the project. I wonder if there are problems in my setting or format, etc. Could you give me a demo about how to create a function combined by C and assembler language?
标记 (3)
1 解答
2,532 次查看
alexanderfedoto
Inline assembly syntax can be slightly different for compilers.
In case you use GCC syntax is described there Using the GNU Compiler Collection (GCC): Extended Asm
在原帖中查看解决方案
1 回复
2,533 次查看
alexanderfedoto
