How to check CPU Usage
3,602 次查看
leekate-b45752
In S32 DS for ARM, how can I check the CPU usage or calculate MIPS?
Also, is there any checking tool about the stack memory usage according to the functions in the SW?
Kate Lee
3,201 次查看
stanish
Hi Kate,
I assume you are using GCC in S32DS.
I found a nice article by Erich related to the static stack usage estimation using gcc tools:
GNU Static Stack Usage Analysis | MCU on Eclipse
If you are using FreeRTOS you can watch dynamic stack usage of each task in the Task List:
For the bareboard setup we don't offer any sophisticated tool for stack usage/CPU usage.
Stan
