How to Set Up S32DS 3.4
Oido
Hello, I'm using nxp mcu using s32ds 3.4. At some point, I was coding with a C file to see if I touched the settings wrong, and when I pressed the PERIPHERALS button at the top left, it not only sets the SDK function, but also follows the C file that I was coding. Also, if you set the SDK function and then press the C/C++ icon again to return to the part where you write the code, the previous SDK part will follow.
I used to use each as a separate space before, but I don't know why it's following. Is there a setting I can fix?
VaneB
Hi @Oido
Could you please try Reset Perspective (Window > Perspective)?
BR, VaneB
VaneB
Hi @Oido
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-1913874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20Set%20Up%20S32DS%203.4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F289634iD2925E38E804418E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F289633i728DCB135B866384%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHello%2C%20I'm%20using%20nxp%20mcu%20using%20s32ds%203.4.%20At%20some%20point%2C%20I%20was%20coding%20with%20a%20C%20file%20to%20see%20if%20I%20touched%20the%20settings%20wrong%2C%20and%20when%20I%20pressed%20the%20PERIPHERALS%20button%20at%20the%20top%20left%2C%20it%20not%20only%20sets%20the%20SDK%20function%2C%20but%20also%20follows%20the%20C%20file%20that%20I%20was%20coding.%20Also%2C%20if%20you%20set%20the%20SDK%20function%20and%20then%20press%20the%20C%2FC%2B%2B%20icon%20again%20to%20return%20to%20the%20part%20where%20you%20write%20the%20code%2C%20the%20previous%20SDK%20part%20will%20follow.%3CBR%20%2F%3EI%20used%20to%20use%20each%20as%20a%20separate%20space%20before%2C%20but%20I%20don't%20know%20why%20it's%20following.%20Is%20there%20a%20setting%20I%20can%20fix%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1914424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20Set%20Up%20S32DS%203.4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1914424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226367%22%20target%3D%22_blank%22%3E%40Oido%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20try%20Reset%20Perspective%20(Window%20%26gt%3B%20Perspective)%3F%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
