How to S32's break point timestamp in running
2,534 次查看
guoqiang_zhu
   I want to konw the time consumed from breakpoint A to breakpoint B. but I don't know how to do it.
background:
  a. Project quesion is MCU Init time too long , I think the time cost in StartUp step .
  b.address 0x01000400 is my StartUp's Entry point , address 0x01008e24 is my MainFunc()'s Entry point.
thanks.
2,431 次查看
jiri_kral
I'm afraid that PE Micro isn't able measure running time.
You can attach one channel of oscilloscope to Reset. Add as a very first instruction in main pin toggle. Catch this pin toggle on second oscilloscope channel. You got time from reset to main.
Anyway, what's your target MCU?
Jiri
2,432 次查看
jiri_kral
Jiri
2,431 次查看
guoqiang_zhu
Thanks for you response.My target mcu is MPC5746C.
And oscilloscope can slove my current problem by adding two pins toggle channel.
