How to Place a C file contents to a user defined memory section
sarathkc351
how can i update linker file so that all the functions (say Fls.c) file will be moved to user defined memory section.I tried below code but is not working.code is compiling but size of  int_fls_rsv is zero.
.fls_code_rom :
. = ALIGN(4);
*Fls.o(.text .text*)
} > int_fls_rsv
stanish
I'd invite you to see this Howto document:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Execute-a-library-function-from-...
perhaps you could try to exclude specific object file using (EXCLUDE_FILE) from .text section
 .text :
    . = ALIGN(4);
     /* Exclude fsl.o from .text.* section  */
    *(EXCLUDE_FILE (*fsl.o) .text*)
and then place it into your custom section:
.fls_code_rom :
. = ALIGN(4);
 *Fls.o(.text*)
} > int_fls_rsv
Hope it helps.
Stan
