How do I obtain a new activation code with a valid license period?
615 次查看
masanobunishimu
I need to use "S32DS for Arm 2018.R1" again.
The activation code ("CA1E-5E8C-4B42-0655") I downloaded today shows as expired (Feb 24, 2022) in the License List.
(Therefore, offline activation also fails.)
How can I obtain a new "Activation Code" with a valid license expiration date?
590 次查看
stanish
I've just  fixed your license expiration date. Please use the same activation code to activate/refresh the license either online or offline.
Hope it helps
Stan
591 次查看
stanish
Hope it helps
Stan
563 次查看
masanobunishimu
Thank you for your assistance.
After deleting the folder below and performing the installation,
offline activation ultimately succeeded.
"C:\ProgramData\FLEXnet"
577 次查看
masanobunishimu
Thank you for your support.
However, offline activation still failed.
The contents of "activation.xml" are as follows,
and it still shows "License cannot be generated, it has already expired."
I would appreciate any advice on additional troubleshooting steps.
```xml: activation.xml
<?xml version="1.0" encoding="UTF-8" ?>
    <ResponseHeader>
        <VersionNumber>1</VersionNumber>
        <ResponseType>FAILURE</ResponseType>
        <RequestSequenceNumber>10</RequestSequenceNumber>
        <RequestHash>9E6B420F28F0F9C76D6E44B2108A35D7CF94AABF</RequestHash>
    </ResponseHeader>
    <ResponseData>
        <ResponseReason>DENIED</ResponseReason>
        <ErrorCode>License can not be generated, it is already expired.</ErrorCode>
    </ResponseData>
    <Signature>C652403DBD48EB68DCF2D781A737EEEB9B2DCE16</Signature>
    <SignatureVersion>1</SignatureVersion>
</Response>
I have attached the formatted XML file and the results of checking the License Lists status. Please review these as well.
