Greenhills plug in
Greenhills plug in
9,935 次查看
leekate-b45752
Some errors occurred when I try to install GHS plug-in as below in S32DS 2018 R1 for ARM, could you check about it?
And is there GHS plug-in install guidance material?
Kate Lee
标记 (3)
8,161 次查看
Mehul_Patel_NXP
Hi, Rohan,
As GHS is proprietary compiler provider, you would need to buy license for GHS. And you would need to install Greenhills "eclipse" plugin to use it on S32Design Studio.
Also, please check this link for guide to use GHS plugin
Please let us know if you face any further issue.
Thank you. Kind regards.
- Mehul Patel
5 回复数
8,229 次查看
RohanD
Can you please provide GHS Plugin that does support S32 design studio.
I tries connecting to the GHS team, they mentioned to get it from NXP.
I need it urgently.
8,162 次查看
Mehul_Patel_NXP
Hi, Rohan,
- Mehul Patel
9,744 次查看
stanish
Hi Kate,
Indeed you will  need a newer version of GHS plugin supported by neon v2.2.5+. See below:
Hope it helps.
Stan
9,744 次查看
jiri_kral
Hi Kate,
If you already have GHS plugin compatible with Eclipse Neon - try to remove support for 68K/ColdFire - if you don't need it.. The error message looks that is related to this part only.
Jiri
9,744 次查看
mikedoidge
Hi leekate-b45752‌,
The GHS Plugin does not support Eclipse Neon. S32 Design Studio for ARM migrated to Eclipse Neon in Release 2018.R1. If a user wishes to use the GHS Plugin on Eclipse Neon, then they must contact GreenHills support.
Mike
