Error while running the program in S32 Design Studio
Krishna_Yalamanchili
I am getting the following error when Run is pressed in S32 Design studio. I am trying to run after debug file is flashed and run. Please suggest what I have to do if i have to run the application only.
Error starting process.
Cannot run program "C:\Users\kyalamanchilli\workspaceS32DS.Power.2.1\hello_world_mpc5777c\Debug_FLASH\hello_world_mpc5777c.elf": Launching failed
mikedoidge
Hello @Krishna_Yalamanchili,
Are you trying to just run or also debug?
If the application has been flashed successfully, then you just cycle the power to the board and it should run.
Mike
