Debug (F11) always ask for Debug Device Settings.
tom_orsi1
F11 - Debug always asks me to set the device for debugging which is OpenSDA. I tried to set this in the project settings and its not even recognized.
The Debugging works fine but each time I F11 I have to set the two drop downs the Open SDA and the actual device.
Great debugging environment btw, I have had a chance to use one of these in 15 years!
Tom
Tags (3)
tom_orsi1
never mind i found it, i had to access the projects explorer | select target | properties | debugger ....
