DS32 1.2 - Memory Monitor not working right
markthompson170
The memory monitor will not work all the time.
I can add new Rendering put in a Var Name or address (0x4001000) and it display some other address and nothing in the “Monitors” list.
If I shut it down and restart DS32 it sometimes comes back and works for a while.
This happened a few times in 1.1 but in 1.2 it happens all the time.
Also if you are looking at something in the EmbSys viewer and you select the Memory monitor it changes to “-not read-“ in the EmbSys value.
Mark
stanish
Hi mark,
Thank you for this report.
I'm able to reproduce this issue and I logged it into our defect tracking database.
The workaround is to close the Memory Monitor View and reopen it again:
regarding embsys registers view - Reproducible as well and I've noticed the workaround could be doing a single debug step which refreshes the view.
Anyway, these issues are currently analyzed by our engineering team.
regards,
Stan
