Bytes to Float not working
1,982 次查看
Marcos_Eztronic
Hello all.
I am trying to convert some bytes that I receive from CAN to a float variable.
However, the result is not correctly. I tried to change from little endian to big endian, not works.
For example, I am receiving the data 0x40333333, it`s suposed to be 2.8, but the result is totally different.
The images below will help to explain the situation (the variable that I am focusing in this example is cellParams.underVoltage
- variable initialiazion
cellParams.underVoltage = 2.80;
- initialization confirmation:
So after the initialization, I will send a CAN command to change the value (I will send the same value)
The new value is in the image below, from buffer position 3 until 6
When I receive the buffer, I try to do the following:
int dummyInt = DeserializeInt32(&cmdMsg->data[3]);
//cellParams.underVoltage = atof(&cmdMsg->data[3]); (same problem...)
cellParams.underVoltage = (float)(dummyInt);
static uint32_t DeserializeUint32(const uint8_t *buffer)
    int value = 0;
    value += (int)buffer[3] << 24U;
    value += (int)buffer[2] << 16U;
    value += (int)buffer[1] << 8U;
    value += (int)buffer[0];
    return value;
the returned value to dummyInt is OK:
The float value, before cellParams.underVoltage = (float)(dummyInt), is:
And after cellParams.underVoltage = (float)(dummyInt), is:
but if I check the variable (not in memory monitor), the hex value looks fine, but the float value lookw incorrect:
PS.: I tried atof, memcpy, not success.
Could someone help me? Thanks in advance!
1,912 次查看
Marcos_Eztronic
Hello, thank you so much for the answer.
Memcpy not worked for me, but I found another solution (thats similar to memcpy, but that`s the onlyone that worked...)
static float DeserializeFloat(const uint8_t *buffer)
uint32_t value = 0;
value |= buffer[3] << 24U;
value |= buffer[2] << 16U;
value |= buffer[1] << 8U;
value |= buffer[0];
float f = *((float*)&value);
return f;
Anyway, thank you very much for your time.
1,922 次查看
jiri_kral
I tried it on my side and only working method for me is memcpy - like this:
unsigned int counter = 0x40333333;
float f=0.0;
memcpy(&f,&counter,4);
1,913 次查看
Marcos_Eztronic
uint32_t value = 0;
value |= buffer[0];
return f;
%3CLINGO-SUB%20id%3D%22lingo-sub-2000140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AD%97%E8%8A%82%E8%BD%AC%E6%B5%AE%E7%82%B9%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E4%BB%8E%20CAN%20%E6%8E%A5%E6%94%B6%E7%9A%84%E4%B8%80%E4%BA%9B%E5%AD%97%E8%8A%82%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%AE%E7%82%B9%E5%8F%98%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E7%BB%93%E6%9E%9C%E5%B9%B6%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%E5%B0%8F%E7%AB%AF%E6%94%B9%E4%B8%BA%E5%A4%A7%E7%AB%AF%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%88%91%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%200x40333333%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E6%98%AF%202.8%EF%BC%8C%E4%BD%86%E7%BB%93%E6%9E%9C%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%9B%BE%E7%89%87%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%A7%A3%E9%87%8A%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%88%E6%88%91%E5%9C%A8%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E4%B8%AD%E5%85%B3%E6%B3%A8%E7%9A%84%E5%8F%98%E9%87%8F%E6%98%AF%3CSTRONG%3EcellParams.underVoltage%3C%2FSTRONG%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E-%20%E5%8F%98%E9%87%8F%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%E7%94%B5%E6%B1%A0%E5%8F%82%E6%95%B0.%E6%AC%A0%E5%8E%8B%3D2.80%EF%BC%9B%3C%2FP%3E%3CP%3E-%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%A1%AE%E8%AE%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312030iEEBE591E30C0CC65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_1-1732282497069.png%22%20alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E5%88%9D%E5%A7%8B%E5%8C%96%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%86%E5%8F%91%E9%80%81%E4%B8%80%E4%B8%AA%20CAN%20%E5%91%BD%E4%BB%A4%E6%9D%A5%E6%9B%B4%E6%94%B9%E8%AF%A5%E5%80%BC%EF%BC%88%E6%88%91%E5%B0%86%E5%8F%91%E9%80%81%E7%9B%B8%E5%90%8C%E7%9A%84%E5%80%BC%EF%BC%89%3C%2FP%3E%3CP%3E%E6%96%B0%E5%80%BC%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E4%BB%8E%E7%BC%93%E5%86%B2%E5%8C%BA%E4%BD%8D%E7%BD%AE%203%20%E5%88%B0%206%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-left%22%20image-alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20style%3D%22width%3A%20722px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20style%3D%22width%3A%20722px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312031i2932CAF28C1972E2%2Fimage-dimensions%2F722x640%3Fv%3Dv2%22%20width%3D%22722%22%20height%3D%22640%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_2-1732282634455.png%22%20alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E6%94%B6%E5%88%B0%E7%BC%93%E5%86%B2%E5%8C%BA%E6%97%B6%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3Eint%20dummyInt%20%3D%20DeserializeInt32(%26amp%3BcmdMsg-%26gt%3Bdata%5B3%5D)%3B%3CBR%20%2F%3E%20%2F%2FcellParams.%E6%AC%A0%E5%8E%8B%3D%20atof(%26amp%3BcmdMsg-%26gt%3Bdata%5B3%5D)%3B%20(%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98...)%3CBR%20%2F%3E%20cellParams.%E6%AC%A0%E5%8E%8B%3D%EF%BC%88%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%89%EF%BC%88dummyInt%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CDIV%3E%E9%9D%99%E6%80%81%20uint32_t%20DeserializeUint32%EF%BC%88const%20uint8_t%20*buffer%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eint%E5%80%BC%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%2B%3D%20(int)%E7%BC%93%E5%86%B2%E5%8C%BA%5B3%5D%20%26lt%3B%26lt%3B%2024U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%2B%3D%20(int)%E7%BC%93%E5%86%B2%E5%8C%BA%5B2%5D%20%26lt%3B%26lt%3B%2016U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%2B%3D%20(int)%E7%BC%93%E5%86%B2%E5%8C%BA%5B1%5D%20%26lt%3B%26lt%3B%208U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%2B%3D%20%EF%BC%88int%EF%BC%89%E7%BC%93%E5%86%B2%E5%8C%BA%5B0%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%E5%80%BC%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%94%E5%9B%9E%E7%BB%99%20dummyInt%20%E7%9A%84%E5%80%BC%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9A%84%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20style%3D%22width%3A%20310px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312034iB879995DC7B1F72E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_3-1732282807587.png%22%20alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3EcellParams.underVoltage%20%E4%B9%8B%E5%89%8D%E7%9A%84%E6%B5%AE%E7%82%B9%E5%80%BC%3D%EF%BC%88float%EF%BC%89%EF%BC%88dummyInt%EF%BC%89%EF%BC%8C%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20style%3D%22width%3A%2092px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312037iE4BFA2216DD1B948%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_4-1732282862589.png%22%20alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%20cellParams.underVoltage%20%E4%B9%8B%E5%90%8E%3D%EF%BC%88float%EF%BC%89%EF%BC%88dummyInt%EF%BC%89%EF%BC%8C%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20style%3D%22width%3A%20632px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20style%3D%22width%3A%20632px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312038i3C94EBE926FE050C%2Fimage-dimensions%2F632x49%3Fv%3Dv2%22%20width%3D%22632%22%20height%3D%2249%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_5-1732283003922.png%22%20alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E6%88%91%E6%A3%80%E6%9F%A5%E5%8F%98%E9%87%8F%EF%BC%88%E4%B8%8D%E5%9C%A8%E5%86%85%E5%AD%98%E7%9B%91%E8%A7%86%E5%99%A8%E4%B8%AD%EF%BC%89%EF%BC%8C%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%80%BC%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%B5%AE%E7%82%B9%E5%80%BC%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%9A%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312039i8DA1EE2D0425534F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_6-1732283097162.png%22%20alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3EPS.%EF%BC%9A%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%3CSPAN%3Eatof%EF%BC%8Cmemcpy%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E5%90%97%EF%BC%9F%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2001037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%AD%97%E8%8A%82%E8%BD%AC%E6%B5%AE%E7%82%B9%E6%97%A0%E6%95%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2001037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3EMemcpy%20%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%88%E7%B1%BB%E4%BC%BC%E4%BA%8E%20memcpy%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E5%94%AF%E4%B8%80%E6%9C%89%E6%95%88%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88......%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%E9%9D%99%E6%80%81%E6%B5%AE%E7%82%B9%E6%95%B0DeserializeFloat%EF%BC%88const%20uint8_t%20*buffer%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20value%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%7C%3D%20%E7%BC%93%E5%86%B2%E5%8C%BA%5B3%5D%20%26lt%3B%26lt%3B%2024U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%7C%3D%20%E7%BC%93%E5%86%B2%E5%8C%BA%5B2%5D%20%26lt%3B%26lt%3B%2016U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%20%7C%3D%20%E7%BC%93%E5%86%B2%E5%8C%BA%5B1%5D%20%26lt%3B%26lt%3B%208U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%BC%7C%3D%E7%BC%93%E5%86%B2%E5%8C%BA%5B0%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%B5%AE%E7%82%B9%E6%95%B0%20f%20%3D%20*((%E6%B5%AE%E7%82%B9%E6%95%B0*)%26amp%3B%E5%80%BC)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%20f%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%BD%E5%87%BA%E6%97%B6%E9%97%B4%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%AD%97%E8%8A%82%E8%BD%AC%E6%B5%AE%E7%82%B9%E6%97%A0%E6%95%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%94%AF%E4%B8%80%E6%9C%89%E6%95%88%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%20memcpy%20-%20%E5%B0%B1%E5%83%8F%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%E6%95%B4%E6%95%B0%E8%AE%A1%E6%95%B0%E5%99%A8%20%3D%200x40333333%EF%BC%9B%3CBR%20%2F%3E%E6%B5%AE%E5%8A%A8f%3D0.0%EF%BC%9B%3CBR%20%2F%3E%20memcpy%EF%BC%88%EF%BC%86f%EF%BC%8C%EF%BC%86counter%EF%BC%8C4%EF%BC%89%EF%BC%9B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
