Bytes to Float not working
1,984件の閲覧回数
Marcos_Eztronic
Hello all.
I am trying to convert some bytes that I receive from CAN to a float variable.
However, the result is not correctly. I tried to change from little endian to big endian, not works.
For example, I am receiving the data 0x40333333, it`s suposed to be 2.8, but the result is totally different.
The images below will help to explain the situation (the variable that I am focusing in this example is cellParams.underVoltage
- variable initialiazion
cellParams.underVoltage = 2.80;
- initialization confirmation:
So after the initialization, I will send a CAN command to change the value (I will send the same value)
The new value is in the image below, from buffer position 3 until 6
When I receive the buffer, I try to do the following:
int dummyInt = DeserializeInt32(&cmdMsg->data[3]);
//cellParams.underVoltage = atof(&cmdMsg->data[3]); (same problem...)
cellParams.underVoltage = (float)(dummyInt);
static uint32_t DeserializeUint32(const uint8_t *buffer)
    int value = 0;
    value += (int)buffer[3] << 24U;
    value += (int)buffer[2] << 16U;
    value += (int)buffer[1] << 8U;
    value += (int)buffer[0];
    return value;
the returned value to dummyInt is OK:
The float value, before cellParams.underVoltage = (float)(dummyInt), is:
And after cellParams.underVoltage = (float)(dummyInt), is:
but if I check the variable (not in memory monitor), the hex value looks fine, but the float value lookw incorrect:
PS.: I tried atof, memcpy, not success.
Could someone help me? Thanks in advance!
1,914件の閲覧回数
Marcos_Eztronic
Hello, thank you so much for the answer.
Memcpy not worked for me, but I found another solution (thats similar to memcpy, but that`s the onlyone that worked...)
static float DeserializeFloat(const uint8_t *buffer)
uint32_t value = 0;
value |= buffer[3] << 24U;
value |= buffer[2] << 16U;
value |= buffer[1] << 8U;
value |= buffer[0];
float f = *((float*)&value);
return f;
Anyway, thank you very much for your time.
1,924件の閲覧回数
jiri_kral
I tried it on my side and only working method for me is memcpy - like this:
unsigned int counter = 0x40333333;
float f=0.0;
memcpy(&f,&counter,4);
1,915件の閲覧回数
Marcos_Eztronic
uint32_t value = 0;
value |= buffer[0];
return f;
%3CLINGO-SUB%20id%3D%22lingo-sub-2000140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBytes%20to%20Float%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BF%E3%81%AA%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3ECAN%E3%81%8B%E3%82%89%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8B%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%82%92float%E5%A4%89%E6%95%B0%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%8B%E3%82%89%E3%83%93%E3%83%83%E3%82%B0%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%9C%E5%93%81%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%810x40333333%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812.8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%E3%80%81%E7%8A%B6%E6%B3%81%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99(%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E7%84%A6%E7%82%B9%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%82%8B%E5%A4%89%E6%95%B0%E3%81%AF%3CSTRONG%3EcellParams.underVoltage%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E-%20%E5%A4%89%E6%95%B0%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3EcellParams.underVoltage%20%3D%202.80%3B%3C%2FP%3E%3CP%3E-%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E7%A2%BA%E8%AA%8D%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312030iEEBE591E30C0CC65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_1-1732282497069.png%22%20alt%3D%22Marcos_Eztronic_1-1732282497069.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E3%80%81%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8BCAN%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99(%E5%90%8C%E3%81%98%E5%80%A4%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E5%80%A4%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E4%BD%8D%E7%BD%AE%203%20%E3%81%8B%E3%82%89%206%20%E3%81%BE%E3%81%A7%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-left%22%20image-alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20style%3D%22width%3A%20722px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20style%3D%22width%3A%20722px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312031i2932CAF28C1972E2%2Fimage-dimensions%2F722x640%3Fv%3Dv2%22%20width%3D%22722%22%20height%3D%22640%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_2-1732282634455.png%22%20alt%3D%22Marcos_Eztronic_2-1732282634455.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eint%20dummyInt%20%3D%20DeserializeInt32(%26amp%3BcmdMsg-%26gt%3Bdata%5B3%5D)%3B%3CBR%20%2F%3EcellParams.underVoltage%3D%20atof(%26amp%3BcmdMsg-%26gt%3Bdata%5B3%5D)%3B(%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C...)%3CBR%20%2F%3EcellParams.underVoltage%3D%20(float)(dummyInt)%3B%3C%2FP%3E%3CDIV%3E%E9%9D%99%E7%9A%84%20uint32_t%20DeserializeUint32(const%20uint8_t%20*buffer)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%95%B4%E6%95%B0%E5%80%A4%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%2B%3D%20(int)buffer%5B3%5D%20%26lt%3B%26lt%3B%2024U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%2B%3D%20(int)buffer%5B2%5D%20%26lt%3B%26lt%3B%2016U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%2B%3D%20(int)buffer%5B1%5D%20%26lt%3B%26lt%3B%208U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%2B%3D%20(int)buffer%5B0%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%BB%E3%82%8A%E5%80%A4%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EdummyInt%20%E3%81%B8%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AF%20OK%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20style%3D%22width%3A%20310px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312034iB879995DC7B1F72E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_3-1732282807587.png%22%20alt%3D%22Marcos_Eztronic_3-1732282807587.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3EcellParams.underVoltage%20%E3%81%AE%E5%89%8D%E3%81%AE%20float%20%E5%80%A4%3D%20(float)(dummyInt)%20%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20style%3D%22width%3A%2092px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312037iE4BFA2216DD1B948%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_4-1732282862589.png%22%20alt%3D%22Marcos_Eztronic_4-1732282862589.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81cellParams.underVoltage%20%E3%81%AE%E5%BE%8C%3D%20(float)(dummyInt)%20%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20style%3D%22width%3A%20632px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20style%3D%22width%3A%20632px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312038i3C94EBE926FE050C%2Fimage-dimensions%2F632x49%3Fv%3Dv2%22%20width%3D%22632%22%20height%3D%2249%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_5-1732283003922.png%22%20alt%3D%22Marcos_Eztronic_5-1732283003922.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%A4%89%E6%95%B0(%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%A2%E3%83%8B%E3%82%BF%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81hex%E5%80%A4%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81float%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312039i8DA1EE2D0425534F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Marcos_Eztronic_6-1732283097162.png%22%20alt%3D%22Marcos_Eztronic_6-1732283097162.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3EPS%3A%3CSPAN%3E%E7%A7%81%E3%81%AFatof%E3%80%81memcpy%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99!%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2001037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ABytes%20to%20Float%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2001037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememcpy%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%88%A5%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%9D%E3%82%8C%E3%81%AFmemcpy%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A7%E3%81%99...)%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3Estatic%20float%20DeserializeFloat(const%20uint8_t%20*%E3%83%90%E3%83%83%E3%83%95%E3%82%A1)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%20value%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%7C%3D%20buffer%5B3%5D%20%26lt%3B%26lt%3B%2024U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%7C%3D%20buffer%5B2%5D%20%26lt%3B%26lt%3B%2016U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%7C%3D%20buffer%5B1%5D%20%26lt%3B%26lt%3B%208U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%80%A4%20%7C%3D%20buffer%5B0%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%95%B0%20f%20%3D%20*(((float*)%26amp%3Bvalue)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ef%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%A8%E3%82%82%E3%81%8B%E3%81%8F%E3%80%81%E6%9C%AC%E6%97%A5%E3%81%AF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ABytes%20to%20Float%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E5%94%AF%E4%B8%80%E3%81%AE%E4%BD%9C%E6%A5%AD%E6%96%B9%E6%B3%95%E3%81%AFmemcpy%E3%81%A7%E3%81%99%20-%20%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E6%95%B4%E6%95%B0%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20%3D%200x40333333%3B%3CBR%20%2F%3E%E3%83%95%E3%83%AD%E3%83%BC%E3%83%88%20f%3D0.0%3B%3CBR%20%2F%3Ememcpy(%26amp%3Bf%2C%26amp%3Bcounter%2C4)%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
