Basic example project file for GHS
2,699件の閲覧回数
leekate-b45752
Could I get an basic example project file for GHS with S32K14x?
Kate Lee
タグ(3)
2,530件の閲覧回数
mikedoidge
Hi Kate,
You will first need to contact Green Hills to get the Eclipse Neon compatible plug-in. Then, after you install the plug-in, you should be able to use the New Project from Example wizard to see the Hello World example included in the SDK. Alternatively, you could use the New Project Wizard to create an empty project.
Mike
2,530件の閲覧回数
jiri_kral
Hi Kate,
unfortunately I don't have any GHS examples for S32K144 - hope that someone on community will share something.
Jiri
