Activation problem "S32 Design Studio for e200" - need compiler for "Model Based Toolbox 2.0"
kp1991
Hey Guy's,
I'm also facing activation problems for S32 PA 1.1.
I tried offline and online product activation, but nothing worked for me.
   Offline: "Invalid Offline Response" --->  <ResponseType>CLIENT_CONFIG</ResponseType>
   Online: "Error sending activation request .... (FNP error 50041,41143,34)" (No Firewall, Mobile Network and Company Network)
Actually, I only need the s32 e200 compiler for the new "Model Based Library v2.0" for Matlab. Does anybody know a workaround for my problem?
Any Updates regarding the new Version - seems like the link is down for a while now...? S32 Design Studio for Power v1.1 - Update 1 available
Kevin
sureshkurukundi
I am facing the problem in installing S32 Design studio in Linux machine (Ubuntu 16.04). When I enter the activation code received in the mail in 'S32DS Activation' dialog box and select the activation type as "online" , I am getting the following error, shown in the screen snippet. Please let me know how to resolve this.
Additionally the desktop is connected to the internet. Thank you.Screenshot from 2018-02-22 19-54-01.png.
stanish
Suresh,
I suspect this could be caused by a firewall or an antivirus sw that prevents connection from you computer to the licensing/activation cloud.
I'd recommend you to try use offline activation in this case.
Hope it helps.
Stan
stanish
Hello Matthias, Zhongzheng,
First thank you for you reports and apologize about the delay.
Offline activation issue hot fix has been released. Please check the link below.
S32 Design Studio Offline activation issue hot fix
Hope it helps.
Stan
mbu2015
Hello Stan,
everything is fine now.
Thank you!
The next question is posted already :smileywink:
Mit freundlichem Gruss
With Best Regards
Matthias Busch
Embedded Solutions 2.4 (TD-S24)
IAV GmbH
Visitors:
Kauffahrtei 25
09120 CHEMNITZ
GERMANY
Postal:
Auer Straße 54
09366 STOLLBERG
GERMANY
Phone: +49 371 23 7 - 3 46 69
Fax: +49 371 23 7 - 3 41 12
E-Mail: <mailto:[email protected]>
Internet: http://www.iav.de
Sitz/Registered Office: Berlin,
Registergericht/Registration Court: Amtsgericht Charlottenburg,
Registernummer/Company Registration Number: HRB 21 280,
Geschäftsführer/Managing Directors: Kurt Blumenröder, Michael Schubert,
Kai-Stefan Linnenkohl
Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: Prof.
Dr. Harald Ludanek
Von: stanish <[email protected]>
An: Matthias Busch <[email protected]>,
Datum: 22.05.2017 22:27
Betreff: Re: - Re: Activation
Toolbox 2.0"
NXP Community
Re: Activation problem "S32 Design Studio for e200" - need compiler for
reply from Stanislav Sliva in S32 Design Studio - View the full discussion
below.
Hope it helps.
Stan
Reply to this message by replying to this email, or go to the message on
NXP Community
Start a new discussion in S32 Design Studio by email or at NXP Community
Following Re: Activation problem "S32 Design Studio for e200" - need
compiler for "Model Based Toolbox 2.0" in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email
frequency in your email preferences
mbu2015
I do have the exact same problem and I think I know why: My companies firewall rules prevent the online registration from succeeding as it worked fine on my private computer which is not limitted in that respect.
So you definitely have to fix the offline activation issue as my guess is that otherwise nearly no-one from the automotive industry will (should) be able to use your stuff!
Matthias
stanish
Hello Kevin,
Thanks for your report and we apologize about the inconveniences!
I've checked your activation attempts records and there are offline activation attempts only. Your online registration attempts haven't reached our server. There must be something blocking the communication with our servers. I'll escalate this to the licensing team.
Regarding offline activation issue (Client config response) - we are currently working on a fix. I'm afraid currently there is no workaround.
I'll inform you as soon as there is any update.
Regarding the S32DS power v1.1 update 1 ... this update does not address the issue with offline activation. Anyway I contacted our web team to add this file back into download section - this may take few days.
Thanks for the heads up!
Stan
zhongzhengliu
     I have the same question . I tried offline and online product activation, but nothing worked for me. I hope that you can deal with this problem.
    Thank you
