Troubleshooting: Java Error When Config Tools Used From Command Line
For S32 Design Studio v3.5 and earlier, there is a known issue when the S32 Configuration Tools are invoked from command line from a location outside of the S32DS installation directory.
The following error is reported:
java.lang.reflect.InvocationTargetException
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
        at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
        at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
        at com.nxp.swtools.common.utils.runtime.SingletonProvider.getSingletonInstance(SingletonProvider.java:46)
        at com.nxp.swtools.common.ui.utils.swt.internal.SWTFactory.getSingletonInstance(SWTFactory.java:421)
        at com.nxp.swtools.common.ui.utils.swt.SWTFactoryProxy.getSingletonInstance(SWTFactoryProxy.java:448)
        at com.nxp.swtools.dcd.controller.DCDController.getInstance(DCDController.java:84)
        at com.nxp.swtools.dcd.DCDStartup.earlyStartup(DCDStartup.java:23)
        at com.nxp.swtools.provider.SWToolsPlatform.initializeAllTools(SWToolsPlatform.java:702)
        at com.nxp.swtools.framework.Application.start(Application.java:475)
        at com.nxp.swtools.framework.Application.start(Application.java:445)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.base/java.lang.reflect.Method.invoke(Unknown Source)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
Caused by: java.lang.NoClassDefFoundError: javafx/beans/property/SimpleBooleanProperty
        at com.nxp.swtools.bootimage.controller.ABootController.<init>(ABootController.java:37)
        at com.nxp.swtools.dcd.dcf.common.DCDCommonController.<init>(DCDCommonController.java:90)
        at com.nxp.swtools.dcd.controller.DCDController.<init>(DCDController.java:43)
        ... 24 more
Caused by: java.lang.ClassNotFoundException: javafx.beans.property.SimpleBooleanProperty cannot be found by com.nxp.swtools.bootimage_1.0.0.202207251223
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:519)
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:170)
        at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
Resolution:
To resolve the issue:
  1. Invoke the command from within the installation directory, for example, from 'C:\NXP\S32DS.3.5\eclipse'
    OR
  2. Change "{S32DS Installation Folder}\eclipse\s32ds.ini" by setting the javafx path from relative to absolute. So, if default installation is used, then:
    Change
    -Defxclipse.java-modules.dir=jre/javafx-sdk-11.0.2/lib
    To
    -Defxclipse.java-modules.dir=C:/NXP/S32DS.3.5/eclipse/jre/javafx-sdk-11.0.2/lib
In addition, if it is desired to suppress unimportant warning messages:
go to {S32DS installation folder}\eclipse\configuration, open logging.properties file and change com.nxp.swtools.level = SEVERE
%3CLINGO-SUB%20id%3D%22lingo-sub-1585714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%EF%BC%9A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%20Java%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1585714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32%20Design%20Studio%20v3.5%20%E4%BB%A5%E5%89%8D%E3%81%A7%E3%81%AF%E3%80%81S32%20Configuration%20Tools%20%E3%82%92%20S32DS%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%3CSTRONG%3E%E3%81%AE%E5%A4%96%E9%83%A8%3C%2FSTRONG%3E%20%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%80%81%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Ejava.lang.reflect.InvocationTargetException%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native%20Method)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjava.lang.reflect.Constructor.newInstance(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.common.utils.runtime.SingletonProvider.getSingletonInstance(SingletonProvider.java%3A46)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.common.ui.utils.swt.internal.SWTFactory.getSingletonInstance(SWTFactory.java%3A421)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.common.ui.utils.swt.SWTFactoryProxy.getSingletonInstance(SWTFactoryProxy.java%3A448)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.dcd.controller.DCDController.getInstance(DCDController.java%3A84)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.dcd.DCDStartup.earlyStartup(DCDStartup.java%3A23)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.provider.SWToolsPlatform.initializeAllTools(SWToolsPlatform.java%3A702)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.framework.Application.start(Application.java%3A475)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.framework.Application.start(Application.java%3A445)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java%3A203)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java%3A134)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java%3A104)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A401)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A255)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native%20Method)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjava.lang.reflect.Method.invoke(Unknown%20Source)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.equinox.launcher.Main.invokeFramework(Main.java%3A654)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.equinox.launcher.Main.basicRun(Main.java%3A591)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.equinox.launcher.Main.run(Main.java%3A1462)%0ACaused%20by%3A%20java.lang.NoClassDefFoundError%3A%20javafx%2Fbeans%2Fproperty%2FSimpleBooleanProperty%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.bootimage.controller.ABootController.%3CINIT%3E(ABootController.java%3A37)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.dcd.dcf.common.DCDCommonController.%3CINIT%3E(DCDCommonController.java%3A90)%0A%20%20%20%20%20%20%20%20at%20com.nxp.swtools.dcd.controller.DCDController.%3CINIT%3E(DCDController.java%3A43)%0A%20%20%20%20%20%20%20%20...%2024%20more%0ACaused%20by%3A%20java.lang.ClassNotFoundException%3A%20javafx.beans.property.SimpleBooleanProperty%20cannot%20be%20found%20by%20com.nxp.swtools.bootimage_1.0.0.202207251223%0A%20%20%20%20%20%20%20%20at%20org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java%3A519)%0A%20%20%20%20%20%20%20%20at%20org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java%3A170)%0A%20%20%20%20%20%20%20%20at%20java.base%2Fjava.lang.ClassLoader.loadClass(Unknown%20Source)%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%3CU%3E%E8%A7%A3%E6%B1%BA%EF%BC%9A%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%8B%E3%82%89%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%8CC%3A%5CNXP%5CS32DS.3.5%5Ceclipse%E3%80%8D%E3%81%8B%E3%82%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%8F%88%E3%81%AF%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%22%7BS32DS%20Installation%20Folder%7D%5Ceclipse%5Cs32ds.ini%22%20%E3%82%92%20javafx%20%E3%83%91%E3%82%B9%E3%82%92%E7%9B%B8%E5%AF%BE%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E7%B5%B6%E5%AF%BE%E3%83%91%E3%82%B9%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A4%89%E3%81%88%E3%82%8B%3C%2FP%3E%0A%3CP%3E-Defxclipse.java-modules.dir%3Djre%2Fjavafx-sdk-11.0.2%2Flib%3C%2FP%3E%0A%3CP%3E%E3%81%B8%3C%2FP%3E%0A%3CP%3E-Defxclipse.java-modules.dir%3DC%3A%2FNXP%2FS32DS.3.5%2Feclipse%2Fjre%2Fjavafx-sdk-11.0.2%2Flib%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AA%E3%81%84%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E6%8A%91%E5%88%B6%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%7BS32DS%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%7D%5Ceclipse%5Cconfiguration%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81logging.properties%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6com.nxp.swtools.level%20%3D%20SEVERE%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-19-2023 01:29 PM
更新者:
