S32 Design Studio for Power Architecture 2017.R1 (Windows/Linux) released!
Product Release Announcement
Automotive Microcontrollers and Processors
2017.R1
The Automotive Microcontrollers and Processors’ Embedded Tools Team at NXP Semiconductors, is pleased to announce the release of the S32 Design Studio for Power Architecture version 2017.R1.
It is the successor of S32 Design Studio for Power v1.2. - the versioning scheme has changed.
Release content (What is new?)
  • Eclipse Neon 4.6 Framework
  • GNU Build Tools for e200 processors (support VLE and BookE ISA, based on gcc 4.9.4 [7.October 2017], binutils 2.28 and gdb 7.8.2) - see the complete GCC release notes
  • Libraries included: newlib, newlib-nano and Freescale EWL2
  • P&E Multilink/Cyclone/OpenSDA (with P&E GDB Server) - updated (v1.7.2.201709281658)
  • New Project wizard to create application and library projects for supported devices
  • Peripherals Register and Special Purpose Registers View
  • Fully integrated MPC5748G/MPC5746C SDK EAR v.0.8.1. For the details on the feature set of SDK please refer to SDK Release notes attached and Reference Manuals (Please note that SDK has Early Access Release status, which means that there could be some limitations and/or issues. Also note, the SDK is available for Windows host only).
  • SDK management included:
o FreeMASTER Serial Communication driver (v2.0 August 31th 2016)
o Automotive Math and Motor Control Libraries(v1.1.9)
  • Windriver Diab compiler support by new project wizard
  • Lauterbach, iSystem, and PLS debuggers support by new project wizard (The plugins to support Diab, iSystem, Lauterbach are not included and have to be installed from the corresponding update site or installation. The current version of the GreenHills plugin is not compatible with Eclipse Neon version, so it should not be used with this release)
  • Kernel Aware debugging for FreeRTOS, eCOS, OSEK
  • Devices supported:
    • S32R274
    • S32R372
    • MPC5775K, MPC5774K
    • MPC5746R, MPC5745R, MPC5743R
    • MPC5777M
    • MPC5777C
    • MPC5748G, MPC5747G, MPC5746G
    • MPC5744B, MPC5745B, MPC5746B, MPC5744C, MPC5745C, MPC5746C
    • MPC5744P, MPC5743P, MPC5742P, MPC5741P
    • MPC5601P, MPC5602P, MPC5603P, MPC5604P
    • MPC5644B, MPC5644C, MPC5645B, MPC5645C, MPC5646B, MPC5646C
    • MPC5601D, MPC5602B, MPC5602C, MPC5602D, MPC5603B, MPC5603C, MPC5604B, MPC5604C, MPC5605B, MPC5606B, MPC5607B
    • MPC5606S
    • MPC5604E
    • MPC5644A, MPC5642A
    • MPC5643L
    • MPC5676R
    • MPC5632M, MPC5633M, MPC5634M
    • MPC5674F
    • MPC5673K, MPC5674K, MPC5675K
Bug Fixes
  • C preprocessor tool added for C++ projects configuration
  • The makefile generation is updated to fix and issue with building a project on the Korean version of Windows - Code page switch command cannot be executed.
  • The Rename Project functionality is improved to cover referenced projects and launch configurations
Complete S32 Design Studio for Power Architecture 2017.R1 release notes are available here
Installation Notes
To download the installer please visit the S32DS for Power Architecture product page: downloads section.
The installer requires the the NEW Activation ID to be entered during the installation. You should receive an email that includes your Activation ID after starting the installer downloading process:
Technical Support
S32 Design Studio issues are tracked through the S32DS Public NXP Community space:
https://community.nxp.com/community/s32/s32ds
附件
评论
Do I need to install this new version ?
Doesn't it has patches , so that When I run CHeck for Updates in s32 v1.2 , I get the latest version as well ?
Vrushali
The latest version release 2017.R1 includes the new version of Eclipse IDE (neon) - it is not possible to update it via eclipse updater.
Therefore there is no a patch to v1.2 available.
Anyway you can have multiple installations of S32DS installed on your computer - they will work simultaneously.
Hope it helps,
Stan
GCC source code? For a company so concerned with licensing and letting lawyers dictate what we are allowed to see (even when the community could help) you have a habit of glossing over the important bits of other licenses.https://www.gnu.org/licenses/gpl-violation.en.html" title="https://www.gnu.org/licenses/gpl-violatio...
Why open yourself up to litigation over something so trivial? Violations of the GNU Licenses- GNU Project - Free Software Foundation
GNU GENERAL PUBLIC LICENSE
Our General Public Licenses are designed to make sure that you have the freedom to distribute copies of free software (and charge for them if you wish), that you receive source code or can get it if you want it, that you can change the software or use pieces of it in new free programs, and that you know you can do these things.
For example, if you distribute copies of such a program, whether gratis or for a fee, you must pass on to the recipients the same freedoms that you received. You must make sure that they, too, receive or can get the source code. And you must show them these terms so they know their rights.
1. Source Code.
The “Corresponding Source” for a work in object code form means all the source code needed to generate, install, and (for an executable work) run the object code and to modify the work, including scripts to control those activities. However, it does not include the work's System Libraries, or general-purpose tools or generally available free programs which are used unmodified in performing those activities but which are not part of the work. For example, Corresponding Source includes interface definition files associated with source files for the work, and the source code for shared libraries and dynamically linked subprograms that the work is specifically designed to require, such as by intimate data communication or control flow between those subprograms and other parts of the work.
- Full body of the GPLv3: https://www.gnu.org/licenses/gpl-3.0.en.html
Hello Jed,
Thanks for pointing us to this issue.
I'd like to ensure you we do respect our GNU licensing obligations seriously.
The delay between release the binary and GCC source package wasn't intended and does not mean we are trying to bypass these obligations in any sense.
This was caused purely by a human factor.
Therefore I've escalated the issue to appropriate team to prevent this kind of issues in a future releases.
The GCC Source package is now available for download:
https://www.nxp.com/lgfiles/updates/S32DS/S32DS_PA_2017.R1_GCC.tar
Thank you for your valuable comments on nxp community!
Stan
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1105073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%202px%3B%20width%3A%201150px%3B%22%3E%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CTR%20style%3D%22background-color%3A%20%23003883%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22font-weight%3A%20inherit%3B%20height%3A%20181px%3B%22%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%20181px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxp.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxp.png%22%20style%3D%22width%3A%20183px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F12077i4CC7058B86A22116%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22nxp.png%22%20alt%3D%22nxp.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%20height%3A%20181px%3B%20width%3A%20632px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2024pt%3B%20padding%3A%200px%3B%22%3E%E4%BA%A7%E5%93%81%E5%8F%91%E5%B8%83%E5%85%AC%E5%91%8A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018pt%3B%20padding%3A%200px%3B%22%3E%E6%B1%BD%E8%BD%A6%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2024pt%3B%20padding%3A%200px%3B%22%3E%E9%9D%A2%E5%90%91%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3EPower%20%E6%9E%B6%E6%9E%84%E7%9A%84%3C%2FSTRONG%3E%3C%2FSPAN%3ES32%20%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20padding%3A%200px%3B%20color%3A%20%23ff0000%3B%20background%3A%20white%3B%20font-size%3A%2024pt%3B%22%3E%3CSTRONG%3E2017.R1%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%20181px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_Logo_official_2016_scaled.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_Logo_official_2016_scaled.png%22%20style%3D%22width%3A%20374px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F12079i1F6FE7DB0B578B9D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_Logo_official_2016_scaled.png%22%20alt%3D%22S32DS_Logo_official_2016_scaled.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22background-color%3A%20%23003883%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22background-color%3A%20%23ffffff%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ENXP%20%E5%8D%8A%E5%AF%BC%E4%BD%93%E5%85%AC%E5%8F%B8%E7%9A%84%E6%B1%BD%E8%BD%A6%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%B7%A5%E5%85%B7%E5%9B%A2%E9%98%9F%E5%BE%88%E9%AB%98%E5%85%B4%E5%9C%B0%E5%AE%A3%E5%B8%83%E5%8F%91%E5%B8%83%E9%80%82%E7%94%A8%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2015px%3B%22%3E%3CSTRONG%3E%E4%BA%8E%20Power%20Architecture%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2015px%3B%22%3E%3CSTRONG%3E2017%20%E7%89%88%E7%9A%84%20S32%20Design%20Studio%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2014.6667px%3B%22%3E%E5%AE%83%E6%98%AF%20S32%20Design%20Studio%20for%20Power%20v1.2%20%E7%9A%84%E5%90%8E%E7%BB%A7%E8%80%85%E3%80%82-%20%E7%89%88%E6%9C%AC%E6%96%B9%E6%A1%88%E5%B7%B2%E7%BB%8F%E6%94%B9%E5%8F%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1416317209%22%20id%3D%22toc-hId--492762606%22%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId-1071195624%22%20id%3D%22toc-hId-1994750227%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2020px%3B%22%3E%E5%8F%91%E5%B8%83%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2020px%3B%22%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E9%B2%9C%E4%BA%8B%EF%BC%9F%3C%2FSPAN%3E%20%EF%BC%89%3C%2FSTRONG%3E%3C%2FH2%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EEclipse%20Neon%204.6%20%E6%A1%86%E6%9E%B6%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23ff0000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E9%80%82%E7%94%A8%E4%BA%8E%20e200%20%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20GNU%20Build%20Tools%EF%BC%88%E6%94%AF%E6%8C%81%20VLE%20%E5%92%8C%20BookE%20ISA%EF%BC%8C%E5%9F%BA%E4%BA%8E%20gcc%204.9.4%20%5B2017%20%E5%B9%B4%2010%20%E6%9C%88%207%20%E6%97%A5%5D%E3%80%81binutils%202.28%20%E5%92%8C%20gdb%207.8.2%EF%BC%89%20-%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%AF%B7%E5%8F%82%E9%98%85%E5%AE%8C%E6%95%B4%E7%9A%84%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Frelease-note%2FS32DS-POWER-v1-2-RN.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGCC%20%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%8C%85%E5%90%AB%E7%9A%84%E5%BA%93%EF%BC%9Anewlib%E3%80%81newlib-nano%20%E5%92%8C%20Freescale%20EWL2%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EP%26amp%3BE%20Multilink%2FCyclone%2FOpenSDA%EF%BC%88%E5%B8%A6P%26amp%3BE%20GDB%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%89-%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E5%B7%B2%E6%9B%B4%E6%96%B0%EF%BC%88v1.7.2.201709281658%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E7%94%A8%E4%BA%8E%E4%B8%BA%E6%94%AF%E6%8C%81%E7%9A%84%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%93%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%204.35pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%A4%96%E8%AE%BE%E5%AF%84%E5%AD%98%E5%99%A8%E5%92%8C%E4%B8%93%E7%94%A8%E5%AF%84%E5%AD%98%E5%99%A8%E6%9F%A5%E7%9C%8B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%AE%8C%E5%85%A8%E9%9B%86%E6%88%90%E7%9A%84%20MPC5748G%2FMPC5746C%20SDK%20EAR%20v.0.8.1%E3%80%82%E6%9C%89%E5%85%B3%20SDK%20%E5%8A%9F%E8%83%BD%E9%9B%86%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%3C%2FSPAN%3E%E8%AF%B7%E5%8F%82%E9%98%85%E9%9A%8F%E9%99%84%E7%9A%84%20SDK%20%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E5%92%8C%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012px%3B%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8CSDK%20%E5%A4%84%E4%BA%8E%E6%97%A9%E6%9C%9F%E8%AE%BF%E9%97%AE%E7%89%88%E6%9C%AC%E7%8A%B6%E6%80%81%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%99%90%E5%88%B6%E5%92%8C%2F%E6%88%96%E9%97%AE%E9%A2%98%E3%80%82%E5%8F%A6%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%AF%A5%20SDK%20%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20Windows%20%E4%B8%BB%E6%9C%BA%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3ESDK%20%E7%AE%A1%E7%90%86%E5%8C%85%E6%8B%AC%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%203.05pt%200.5in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%93%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Fproducts%252Fpower-management%252Fwireless-charging-ics%252Ffreemaster-run-time-debugging-tool%253AFREEMASTER%253Ffsrch%253D1%2526sr%253D2%2526pageNum%253D1%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20none%3B%20font-size%3A%2015.3333px%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3EFreeMASTER%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%B8%B2%E8%A1%8C%E9%80%9A%E4%BF%A1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88v2.0%202016%20%E5%B9%B4%208%20%E6%9C%88%2031%20%E6%97%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200px%200px%200px%200.5in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%93%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Fproducts%252Fdeveloper-resources%252Frun-time-software%252Fautomotive-software-and-tools%252Fmotor-control-development-solutions%252Fautomotive-math-and-motor-control-library-set%253AAUTOMATH_MCL%253F%2526fsrch%253D1%2526sr%253D1%2526pageNum%253D1%2523overviewExpand%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20none%3B%20font-size%3A%2015.3333px%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3E%E6%B1%BD%E8%BD%A6%E6%95%B0%E5%AD%A6%E5%92%8C%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%BA%93%3C%2FA%3E%EF%BC%88v1.1.9%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E6%94%AF%E6%8C%81%3CA%20href%3D%22https%3A%2F%2Fwww.windriver.com%2Fevaluations%2Fdiab_compiler%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindriver%20Diab%3C%2FA%3E%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E6%94%AF%E6%8C%81%3CA%20href%3D%22http%3A%2F%2Fwww.lauterbach.com%2Fframes.html%3Fhome.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELauterbach%3C%2FA%3E%20%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.isystem.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EiSystem%3C%2FA%3E%E5%92%8C%3CA%20href%3D%22https%3A%2F%2Fwww.pls-mc.com%2Fude-microcontroller-debugger-for-aurix-2nd-generation-aurix-tricore-power-architecture-cortex-arm-sh-2a_xe166-xc2000-xscale-c166-st10-stm32-s32%2Fhome-a-214.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EPLS%3C%2FA%3E%E8%B0%83%E8%AF%95%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%22%3E%EF%BC%88%E6%94%AF%E6%8C%81%20Diab%E3%80%81iSystem%E3%80%81Lauterbach%20%E7%9A%84%E6%8F%92%E4%BB%B6%E6%9C%AA%E5%8C%85%E5%90%AB%E5%9C%A8%E5%86%85%EF%BC%8C%E5%BF%85%E9%A1%BB%E4%BB%8E%E7%9B%B8%E5%BA%94%E7%9A%84%E6%9B%B4%E6%96%B0%E7%AB%99%E7%82%B9%E6%88%96%E5%AE%89%E8%A3%85%E4%B8%AD%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82GreenHills%20%E6%8F%92%E4%BB%B6%E7%9A%84%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E4%B8%8E%20Eclipse%20Neon%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%BA%94%E5%9C%A8%E6%AD%A4%E7%89%88%E6%9C%AC%E4%B8%AD%E4%BD%BF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E9%92%88%E5%AF%B9FreeRTOS%E3%80%81eCOS%E5%92%8COSEK%E7%9A%84%E5%86%85%E6%A0%B8%E6%84%9F%E7%9F%A5%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%94%AF%E6%8C%81%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3ES32R274%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3ES32R372%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5775K%2C%20MPC5774K%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5746R%2C%20MPC5745R%2C%20MPC5743R%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5777M%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5777C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5748G%2C%20MPC5747G%2C%20MPC5746G%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3EMPC5744B%3C%2FSPAN%3E%2C%20MPC5745B%3C%2FSPAN%3E%2C%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EMPC5746B%3C%2FSPAN%3E%2C%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3EMPC5744C%3C%2FSPAN%3E%2C%20MPC5745C%2C%20MPC5746C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5744P%2C%20MPC5743P%2C%20MPC5742P%2C%20MPC5741P%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%20MPC5601P%2C%20MPC5602P%2C%20MPC5603P%2C%20MPC5604P%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5644B%2C%20MPC5644C%2C%20MPC5645B%2C%20MPC5645C%2C%20MPC5646B%2C%20MPC5646C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5601D%2C%20MPC5602B%2C%20MPC5602C%2C%20MPC5602D%2C%20MPC5603B%2C%20MPC5603C%2C%20MPC5604B%2C%20MPC5604C%2C%20MPC5605B%2C%20MPC5606B%2C%20MPC5607B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5606S%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5604E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5644A%2C%26nbsp%3BMPC5642A%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5643L%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5676R%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5632M%2C%20MPC5633M%2C%20MPC5634M%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5674F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EMPC5673K%2C%20MPC5674K%2C%20MPC5675K%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E9%99%84%E5%B1%9E%E5%93%81%E5%85%A5%E9%97%A8%E9%A1%B5%E9%9D%A2%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_25.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_25.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14966i2DD921AC586E2BDA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_25.png%22%20alt%3D%22pastedImage_25.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%20id%3D%22toc-hId--736258839%22%20id%3D%22toc-hId-187295764%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%20id%3D%22toc-hId-1751253994%22%20id%3D%22toc-hId--1620158699%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%20id%3D%22toc-hId--56200469%22%20id%3D%22toc-hId-867354134%22%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%20color%3A%20%23000000%3B%22%3EBug%E4%BF%AE%E5%A4%8D%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E4%B8%BA%20C%2B%2B%20%E9%A1%B9%E7%9B%AE%E9%85%8D%E7%BD%AE%E6%B7%BB%E5%8A%A0%E4%BA%86%20C%20%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E5%B7%A5%E5%85%B7%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E6%9B%B4%E6%96%B0%E4%BA%86%20makefile%20%E7%94%9F%E6%88%90%E4%BB%A5%E4%BF%AE%E5%A4%8D%E5%9C%A8%E9%9F%A9%E8%AF%AD%E7%89%88%20Windows%20%E4%B8%8A%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E7%9A%84%E9%97%AE%E9%A2%98%20-%20%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8C%E4%BB%A3%E7%A0%81%E9%A1%B5%E5%88%87%E6%8D%A2%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E9%87%8D%E5%91%BD%E5%90%8D%E9%A1%B9%E7%9B%AE%E5%8A%9F%E8%83%BD%E5%BE%97%E5%88%B0%E6%94%B9%E8%BF%9B%EF%BC%8C%E4%BB%A5%E6%B6%B5%E7%9B%96%E5%BC%95%E7%94%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%92%8C%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%AE%8C%E6%95%B4%E7%9A%84%20S32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%20%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E7%8E%B0%E5%B7%B2%E5%8F%91%E5%B8%83%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Fdocs%252Fen%252Frelease-note%252FS32DS-2-0-RN.pdf%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20none%3B%20font-size%3A%2015.3333px%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3E%E8%BF%99%E9%87%8C%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1863654932%22%20id%3D%22toc-hId--940100329%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId-623857901%22%20id%3D%22toc-hId-1547412504%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1183596562%22%20id%3D%22toc-hId--260041959%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20bold%3B%20font-size%3A%2022px%3B%22%3E%3CSTRONG%3E%E5%AE%89%E8%A3%85%E8%AF%B4%E6%98%8E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%A6%81%E4%B8%8B%E8%BD%BD%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%20S32DS%20for%20Power%20Architecture%20%E4%BA%A7%E5%93%81%E9%A1%B5%E9%9D%A2%EF%BC%9A%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fs32-design-studio-ide%2Fs32-design-studio-ide-for-power-architecture-based-mcus%3AS32DS-PA%3F%26amp%3Btab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%B8%8B%E8%BD%BD%E9%83%A8%E5%88%86%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E8%A6%81%E6%B1%82%E5%9C%A8%E5%AE%89%E8%A3%85%E8%BF%87%E7%A8%8B%E4%B8%AD%E8%BE%93%E5%85%A5%E6%96%B0%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%E3%80%82%E5%BC%80%E5%A7%8B%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E4%B8%8B%E8%BD%BD%E8%BF%87%E7%A8%8B%E5%90%8E%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BC%9A%E6%94%B6%E5%88%B0%E4%B8%80%E5%B0%81%E5%8C%85%E5%90%AB%E6%82%A8%E7%9A%84%E6%BF%80%E6%B4%BB%20ID%20%E7%9A%84%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F15050i23FF6F5F974426AD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2022px%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%22%3ES32%20Design%20Studio%20%E9%97%AE%E9%A2%98%E9%80%9A%E8%BF%87%20S32DS%20%E5%85%AC%E5%85%B1%20NXP%20%E7%A4%BE%E5%8C%BA%E7%A9%BA%E9%97%B4%E8%BF%9B%E8%A1%8C%E8%B7%9F%E8%B8%AA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211357%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2211462%22%20data-objecttype%3D%2214%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%B7%B2%E5%B0%86%E9%97%AE%E9%A2%98%E4%B8%8A%E6%8A%A5%E7%BB%99%E9%80%82%E5%BD%93%E7%9A%84%E5%9B%A2%E9%98%9F%EF%BC%8C%E4%BB%A5%E9%98%B2%E6%AD%A2%E5%9C%A8%E6%9C%AA%E6%9D%A5%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E5%87%BA%E7%8E%B0%E6%AD%A4%E7%B1%BB%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CJed%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%90%91%E6%88%91%E4%BB%AC%E6%8C%87%E5%87%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%90%91%E4%BD%A0%E4%BB%AC%E4%BF%9D%E8%AF%81%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9E%E8%AE%A4%E7%9C%9F%E5%B0%8A%E9%87%8D%E6%88%91%E4%BB%AC%E7%9A%84%20GNU%20%E8%AE%B8%E5%8F%AF%E4%B9%89%E5%8A%A1%E3%80%82%3C%2FP%3E%3CP%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%92%8C%20GCC%20%E6%BA%90%E5%8C%85%E5%8F%91%E5%B8%83%E4%B9%8B%E9%97%B4%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%9C%89%E6%84%8F%E7%9A%84%EF%BC%8C%E4%B9%9F%E4%B8%8D%E6%84%8F%E5%91%B3%E7%9D%80%E6%88%91%E4%BB%AC%E8%AF%95%E5%9B%BE%E4%BB%A5%E4%BB%BB%E4%BD%95%E6%96%B9%E5%BC%8F%E7%BB%95%E8%BF%87%E8%BF%99%E4%BA%9B%E4%B9%89%E5%8A%A1%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E7%BA%AF%E7%B2%B9%E6%98%AF%E4%BA%BA%E4%B8%BA%E5%9B%A0%E7%B4%A0%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%B7%B2%E5%B0%86%E9%97%AE%E9%A2%98%E4%B8%8A%E6%8A%A5%E7%BB%99%E9%80%82%E5%BD%93%E7%9A%84%E5%9B%A2%E9%98%9F%EF%BC%8C%E4%BB%A5%E9%98%B2%E6%AD%A2%E5%9C%A8%E6%9C%AA%E6%9D%A5%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E5%87%BA%E7%8E%B0%E6%AD%A4%E7%B1%BB%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGCC%20%E6%BA%90%E5%8C%85%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FS32DS%2FS32DS_PA_2017.R1_GCC.tar%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FS32DS%2FS32DS_PA_2017.R1_GCC.tar%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FS32DS%2FS32DS_PA_2017.R1_GCC.tar%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20797px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29808iAE943DE1528D989C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%20nxp%20%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%AE%9D%E8%B4%B5%E6%84%8F%E8%A7%81%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGCC%20%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9F%E5%AF%B9%E4%BA%8E%E4%B8%80%E5%AE%B6%E5%A6%82%E6%AD%A4%E5%85%B3%E6%B3%A8%E8%AE%B8%E5%8F%AF%E8%AF%81%E5%B9%B6%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F454438%3Fsr%3Dinbox%22%20target%3D%22_blank%22%3E%E8%AE%A9%E5%BE%8B%E5%B8%88%E5%86%B3%E5%AE%9A%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%BB%80%E4%B9%88%E5%86%85%E5%AE%B9%E7%9A%84%3C%2FA%3E%E5%85%AC%E5%8F%B8%EF%BC%88%E5%8D%B3%E4%BD%BF%E7%A4%BE%E5%8C%BA%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%89%EF%BC%8C%E6%82%A8%E4%B9%A0%E6%83%AF%E4%BA%8E%E6%8E%A9%E7%9B%96%E5%85%B6%E4%BB%96%E8%AE%B8%E5%8F%AF%E8%AF%81%E7%9A%84%E9%87%8D%E8%A6%81%E9%83%A8%E5%88%86%E3%80%82https%20%3CA%20href%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%22%20title%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%22%20title%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E4%B8%BA%E4%BA%86%E8%BF%99%E4%B9%88%E5%B0%8F%E7%9A%84%E4%BA%8B%E6%83%85%E8%80%8C%E9%99%B7%E5%85%A5%E8%AF%89%E8%AE%BC%EF%BC%9F%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%22%20title%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-violation.en.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%BF%9D%E5%8F%8D%20GNU%20%E8%AE%B8%E5%8F%AF%E8%AF%81%20-%20GNU%20%E9%A1%B9%E7%9B%AE%20-%20%E8%87%AA%E7%94%B1%E8%BD%AF%E4%BB%B6%E5%9F%BA%E9%87%91%E4%BC%9A%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGNU%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%E8%AF%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%201em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E6%88%91%E4%BB%AC%E7%9A%84%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%97%A8%E5%9C%A8%E7%A1%AE%E4%BF%9D%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%87%AA%E7%94%B1%E5%88%86%E5%8F%91%E5%85%8D%E8%B4%B9%E8%BD%AF%E4%BB%B6%E7%9A%84%E5%89%AF%E6%9C%AC%EF%BC%88%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%AF%B9%E5%85%B6%E6%94%B6%E8%B4%B9%EF%BC%89%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%94%B6%E5%88%B0%E6%BA%90%E4%BB%A3%E7%A0%81%E6%88%96%E5%9C%A8%E9%9C%80%E8%A6%81%E6%97%B6%E8%8E%B7%E5%BE%97%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%94%B9%E8%BD%AF%E4%BB%B6%E6%88%96%E5%9C%A8%E6%96%B0%E7%9A%84%E5%85%8D%E8%B4%B9%E7%A8%8B%E5%BA%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%85%B6%E4%B8%AD%E7%9A%84%E9%83%A8%E5%88%86%E5%86%85%E5%AE%B9%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E7%9F%A5%E9%81%93%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%81%9A%E8%BF%99%E4%BA%9B%E4%BA%8B%E6%83%85%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%201em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%88%86%E5%8F%91%E6%AD%A4%E7%B1%BB%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%89%AF%E6%9C%AC%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%98%AF%E5%85%8D%E8%B4%B9%E8%BF%98%E6%98%AF%E6%94%B6%E8%B4%B9%EF%BC%8C%E6%82%A8%E9%83%BD%E5%BF%85%E9%A1%BB%E5%B0%86%E6%82%A8%E6%89%80%E8%8E%B7%E5%BE%97%E7%9A%84%E7%9B%B8%E5%90%8C%E8%87%AA%E7%94%B1%E8%BD%AC%E8%AE%A9%E7%BB%99%E6%8E%A5%E6%94%B6%E8%80%85%E3%80%82%E6%82%A8%E5%BF%85%E9%A1%BB%E7%A1%AE%E4%BF%9D%E4%BB%96%E4%BB%AC%E4%B9%9F%E6%94%B6%E5%88%B0%E6%88%96%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%E4%BD%A0%E5%BF%85%E9%A1%BB%E5%90%91%E4%BB%96%E4%BB%AC%E5%B1%95%E7%A4%BA%E8%BF%99%E4%BA%9B%E6%9D%A1%E6%AC%BE%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%96%E4%BB%AC%E4%BA%86%E8%A7%A3%E8%87%AA%E5%B7%B1%E7%9A%84%E6%9D%83%E5%88%A9%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%201em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E1.%20Source%20Code.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%201em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E5%AF%B9%E4%BA%8E%E7%9B%AE%E6%A0%87%E4%BB%A3%E7%A0%81%E5%BD%A2%E5%BC%8F%E7%9A%84%E4%BD%9C%E5%93%81%EF%BC%8C%E2%80%9C%E5%AF%B9%E5%BA%94%E6%BA%90%E4%BB%A3%E7%A0%81%E2%80%9D%E6%98%AF%E6%8C%87%E7%94%9F%E6%88%90%E3%80%81%E5%AE%89%E8%A3%85%E5%92%8C%EF%BC%88%E5%AF%B9%E4%BA%8E%E5%8F%AF%E6%89%A7%E8%A1%8C%E4%BD%9C%E5%93%81%EF%BC%89%E8%BF%90%E8%A1%8C%E7%9B%AE%E6%A0%87%E4%BB%A3%E7%A0%81%E4%BB%A5%E5%8F%8A%E4%BF%AE%E6%94%B9%E4%BD%9C%E5%93%81%E6%89%80%E9%9C%80%E7%9A%84%E6%89%80%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8C%85%E6%8B%AC%E6%8E%A7%E5%88%B6%E8%BF%99%E4%BA%9B%E6%B4%BB%E5%8A%A8%E7%9A%84%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%83%E4%B8%8D%E5%8C%85%E6%8B%AC%E4%BD%9C%E5%93%81%E7%9A%84%E7%B3%BB%E7%BB%9F%E5%BA%93%EF%BC%8C%E6%88%96%E9%80%9A%E7%94%A8%E5%B7%A5%E5%85%B7%E6%88%96%E9%80%9A%E5%B8%B8%E5%8F%AF%E7%94%A8%E7%9A%84%E5%85%8D%E8%B4%B9%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%BF%99%E4%BA%9B%E7%A8%8B%E5%BA%8F%E6%9C%AA%E7%BB%8F%E4%BF%AE%E6%94%B9%E5%8D%B3%E5%8F%AF%E7%94%A8%E4%BA%8E%E6%89%A7%E8%A1%8C%E8%BF%99%E4%BA%9B%E6%B4%BB%E5%8A%A8%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B1%9E%E4%BA%8E%E4%BD%9C%E5%93%81%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%AF%B9%E5%BA%94%E6%BA%90%E4%BB%A3%E7%A0%81%E5%8C%85%E6%8B%AC%E4%B8%8E%E4%BD%9C%E5%93%81%E6%BA%90%E6%96%87%E4%BB%B6%E7%9B%B8%E5%85%B3%E7%9A%84%E6%8E%A5%E5%8F%A3%E5%AE%9A%E4%B9%89%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BB%A5%E5%8F%8A%E4%BD%9C%E5%93%81%E4%B8%93%E9%97%A8%E8%AE%BE%E8%AE%A1%E9%9C%80%E8%A6%81%E7%9A%84%E5%85%B1%E4%BA%AB%E5%BA%93%E5%92%8C%E5%8A%A8%E6%80%81%E9%93%BE%E6%8E%A5%E5%AD%90%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BE%8B%E5%A6%82%E9%80%9A%E8%BF%87%E8%BF%99%E4%BA%9B%E5%AD%90%E7%A8%8B%E5%BA%8F%E5%92%8C%E4%BD%9C%E5%93%81%E5%85%B6%E4%BB%96%E9%83%A8%E5%88%86%E4%B9%8B%E9%97%B4%E7%9A%84%E7%B4%A7%E5%AF%86%E6%95%B0%E6%8D%AE%E9%80%9A%E4%BF%A1%E6%88%96%E6%8E%A7%E5%88%B6%E6%B5%81%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%201em%200px%3B%22%3E-%26nbsp%3BFull%20body%20of%20the%20GPLv3%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-3.0.en.html%22%20title%3D%22https%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-3.0.en.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.gnu.org%2Flicenses%2Fgpl-3.0.en.html%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%202017.R1%20%E5%8C%85%E5%90%AB%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20Eclipse%20IDE%EF%BC%88neon%EF%BC%89%20-%20%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20eclipse%20%E6%9B%B4%E6%96%B0%E7%A8%8B%E5%BA%8F%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20v1.2%20%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%E5%A4%9A%E4%B8%AA%20S32DS%20-%20%E5%AE%83%E4%BB%AC%E5%B0%86%E5%90%8C%E6%97%B6%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32%20Design%20Studio%20for%20Power%20Architecture%202017.R1%EF%BC%88Windows%2FLinux%EF%BC%89%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E8%BF%99%E4%B8%AA%E6%96%B0%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%AE%83%E6%B2%A1%E6%9C%89%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%BD%93%E6%88%91%E5%9C%A8%20s32%20v1.2%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E6%A3%80%E6%9F%A5%E6%9B%B4%E6%96%B0%E6%97%B6%EF%BC%8C%E6%88%91%E4%B9%9F%E4%BC%9A%E5%BE%97%E5%88%B0%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%BC%97%E9%B2%81%E6%B2%99%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-31-2017 09:10 AM
更新人:
