S32 Design Studio for ARM 2018.R1 (Windows/Linux) released!
Product Release Announcement
Automotive Microcontrollers and Processors
2018.R1
February 6, 2017
NXP Semiconductors is pleased to announce the release of the S32 Design Studio for ARM 2018.R1 for Automotive and Ultra-Reliable MCUs. The S32 Design Studio is based on the Eclipse open development platform and integrates the Eclipse IDE, GNU Compiler Collection (GCC), GNU Debugger (GDB), and other open-source software to offer designers a straightforward development tool with no code-size limitations.
Red highlighted items below are new/updated features in comparison to previous releases/updates.
Release content (What is new?)
  • Eclipse Neon 4.6 Framework
  • GNU Tools for ARM® Embedded Processors (Launchpad) build (4.9.3 20150529)
  • ARM64: Linaro GCC 4.9-2015.05
  • GNU Tools for ARM® Embedded Processors build (6.3.1 20170824) - supported by New Project Wizard for S32K1xx device. See the complete GNU ARM 6.3.1 release notes attached below.
    GCC Source code package is available here.
  • Libraries included: newlib, newlib-nano and ewl2 (ewl and ewlnano).
  • GDB 7.12.1 with Python
  • P&E Multilink/Cyclone/OpenSDA (with P&E GDB Server) - updated (v3.3.5.201801101746)
  • SEGGER J-Link (with SEGGER GDB Server) - updated (V6.22e_B180108)
  • New Project wizard to create application and library projects for supported devices
  • Fully integrated S32 SDK for S32K14x EAR release v.0.8.6. For the details on the feature set of SDK please refer to SDK Release notes and Reference Manuals. S32 SDK Release notes attached.Please note that S32K SDK has Early Access Release status, that means that there could be some limitations and issues. The S32K SDK is available for Windows host only. There is limitation on the supported GreenHills compiler version – the SDK released with GreenHills v2014.4, but due to GreenHills plugin limitation support for GreenHills compiler v2017.1 integrated, so new project wizard would not provide possibility to create SDK project with GreenHills compiler.
  • SDK management included
  • Import projects from CodeWarrior for MCU v.10.6 and Kinetis Design Studio for respective supported processors
  • IAR v7.x and v8.11.2 compiler support by new project wizard
  • GreenHills v2017.1.4 compiler support by new project wizard
  • iSystem, Lauterbach and IAR debuggers support by new project wizard.
  • Kernel Aware debugging for FreeRTOS, OSEK.
  • MQX 4.2 for MAC57D54H with possibility to create project from example
  • Devices supported
    • SKEAZN8, SKEAZN16, SKEAZN32, SKEAZN64, SKEAZ128, SKEAZ64
    • S32K144 v2.0, S32K142, S32K146, S32K148
    • S32V234
    • MAC57D54
  • Getting started page to allow the centralized access to documentation and additional materialspastedImage_42.png
Bug Fixes
  • Updated header and register description files to fix issues and synchronize with latest Ref Manual versions
  • [S32DS-4629] Clean rule doesn't work after particular user actions in "C/C++ Build -> Behavior"
  • [S32DS-301] After some debugging work (using BP, Stepping, Resume...) Disassembly view content disappears.
  • [S32DS-1093] Debugging session hangs when "c" step over is done on a loop statement that has its entire block in a single line.
  • [S32DS-273] Can not suspend after set condition of breakpoint = 0 and resume
  • [S32DS-61] Breakpoint properties disappeared after right-click into breakpoint
  • [S32DS-6072] Unable to export S32K144 SDK project into ProjectInfo.xml
The complete S32 Design Studio for ARM 2018.R1 release notes are attached below.
Installation Notes
Please visit the S32DS for ARM product page - download section to download the installer.
The installer requires the NEW Activation ID to be entered during the installation.
You should receive an email that includes your Activation ID after starting the download.
Technical Support
S32 Design Studio issues are tracked through the S32DS Public NXP Community space:
https://community.nxp.com/community/s32/s32ds
添付
コメント
I USE MY ACTIVATE CODE FROM MY email from NXP,BUT ONLINE activation error!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Any body know why???
I use one way that has been  suggested in other sections (use offline )
Hello Wei,
Thanks for your report. It's indeed recommended to use offline activation instead of online if there is any issue with online activation.
There are several circumstances that can cause the online activation attempt fails - e.g. firewall/antivirus setup, company network setup, network lags...
According to our records the offline activation transaction was successful so I assume you are now up and running.
regards,
Stan
According to the release notes the SDK is only supported on Windows Host. When will it be released for Linux ?
Sumit
Dear  Stanislav Sliva
       Could you please tell me how to use the (S32 Design Studio for ARM® 2018.R1 Update 2 – S32K116 Device Support & S32 SDK EAR 1.8.7 for S32K116(REV UP2) NEW)  of S32 Design Studio for ARM 2018.R1?
        Which folder  location  should i put those extracted files?
       Thanks!
      Ean
You don't have to extract the files from archive.
Please see this release announcement for the update - it contains installation instructions.
https://community.nxp.com/docs/DOC-340264
Hope it helps.
Stan
Sumit,
You are right, unfortunately SDK is currently not supported by Linux version of S32 Design Studio.
This issue has been already escalated to the marketing team and there is pending discussion about adding SDK support into linux version of the S32 Design Studio.
I'd not expect it will happens in a near future (this year).
Stan
Thanks Stan, any reason why we couldn't copy over and use the SDK source files from Linux? We are interested in the startup files and peripheral drivers.
I download the software,but found no menu to update, someone can help me ?  I want to update offline .111.JPG
you can update your installation by Install New Software option. I'm not sure if you have only WIN XP look or real Windows XP - if Real Win XP, please be aware that Windows XP is not supported by S32DS and you may be facing some issues.
Jiri
%3CLINGO-SUB%20id%3D%22lingo-sub-1112289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%200px%202px%3B%20width%3A%201150px%3B%22%3E%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CTR%20style%3D%22background-color%3A%20%23003883%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22font-weight%3A%20inherit%3B%20height%3A%20181px%3B%22%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%20181px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxp.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxp.png%22%20style%3D%22width%3A%20183px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4675iB938AB87219891C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22nxp.png%22%20alt%3D%22nxp.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Enxp.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%20height%3A%20181px%3B%20width%3A%20632px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2024pt%3B%20padding%3A%200px%3B%22%3E%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018pt%3B%20padding%3A%200px%3B%22%3E%E8%BB%8A%E8%BC%89%E7%94%A8%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%EF%BC%8F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2024pt%3B%20padding%3A%200px%3B%22%3EARM%E7%94%A8S32%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20padding%3A%200px%3B%20color%3A%20%23ff0000%3B%20background%3A%20white%3B%20font-size%3A%2024pt%3B%22%3E%3CSTRONG%3E2018%E5%B9%B4R1%E6%9C%88%E5%8F%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%20181px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_Logo_official_2016_scaled.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS_Logo_official_2016_scaled.png%22%20style%3D%22width%3A%20374px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4672i37A9EDEED87CEB94%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS_Logo_official_2016_scaled.png%22%20alt%3D%22S32DS_Logo_official_2016_scaled.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS_Logo_official_2016_scaled.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22background-color%3A%20%23003883%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22background-color%3A%20%23ffffff%3B%20font-weight%3A%20inherit%3B%20height%3A%2024px%3B%22%3E%3CTD%20style%3D%22background-image%3A%20initial%3B%20background-position%3A%20initial%3B%20background-size%3A%20initial%3B%20background-repeat%3A%20initial%3B%20background-attachment%3A%20initial%3B%20background-origin%3A%20initial%3B%20background-clip%3A%20initial%3B%20font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20175px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.0pt%3B%22%3E%3CEM%3E2017%E5%B9%B42%E6%9C%886%E6%97%A5%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20padding%3A%202pt%203pt%3B%20width%3A%20632px%3B%20height%3A%2024px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ENXP%20Semiconductors%E3%81%AF%E3%80%81%E8%BB%8A%E8%BC%89%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E8%B6%85%E9%AB%98%E4%BF%A1%E9%A0%BC%E6%80%A7MCU%20%3CSTRONG%3E%E5%90%91%E3%81%91%E3%81%AEARM%202018.R1%E7%94%A8%E3%81%AES32%20Design%20Studio%3C%2FSTRONG%3E%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E7%99%BA%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82S32%20Design%20Studio%E3%81%AF%E3%80%81Eclipse%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81Eclipse%20IDE%E3%80%81GNU%20Compiler%20Collection(GCC)%E3%80%81GNU%20Debugger(GDB)%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AE%E3%81%AA%E3%81%84%E7%B0%A1%E5%8D%98%E3%81%AA%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E8%A8%AD%E8%A8%88%E8%80%85%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1415481102%22%20id%3D%22toc-hId--492732938%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%20color%3A%20%23ff0000%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%B5%A4%E3%81%8F%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E9%A0%85%E7%9B%AE%E3%81%AF%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2F%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%9F%E6%96%B0%E6%A9%9F%E8%83%BD%2F%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId-1072031731%22%20id%3D%22toc-hId-1994779895%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--735422732%22%20id%3D%22toc-hId-187325432%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20border%3A%200px%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2020px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20border%3A%200px%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2020px%3B%22%3E%E6%96%B0%E6%A9%9F%E8%83%BD)%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FH2%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%82%AF%E3%83%AA%E3%83%97%E3%82%B9%E3%83%8D%E3%82%AA%E3%83%B3%204.6%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EARM%C2%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8GNU%E3%83%84%E3%83%BC%E3%83%AB(%E3%83%A9%E3%83%B3%E3%83%81%E3%83%91%E3%83%83%E3%83%89)%E3%83%93%E3%83%AB%E3%83%89(4.9.3%2020150529)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EARM64%3A%20Linaro%20GCC%204.9-2015.05%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3EARM%C2%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8GNU%E3%83%84%E3%83%BC%E3%83%AB%E3%83%93%E3%83%AB%E3%83%89(6.3.1%2020170824)%20%3C%2FSTRONG%3E-%20%3CSPAN%20style%3D%22border%3A%200px%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%20S32K1xx%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BGNU%20ARM%206.3.1%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E5%85%A8%E6%96%87%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSTRONG%3E%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%20none%3B%20color%3A%20%23ff0000%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3EGCC%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FS32DS%2Fgcc-6.3-arm32-eabi-i686-sources-g7fea41d.tar%22%20style%3D%22border%3A%200px%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%80%82%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3A%20newlib%2C%20newlib-nano%20%E3%81%8A%E3%82%88%E3%81%B3%20ewl2%20(ewl%20%E3%81%A8%20ewlnano)%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EGDB%207.12.1%20%E3%81%A8%20Python%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EP%26amp%3BE%20Multilink%2FCyclone%2FOpenSDA%20(P%26amp%3BE%20GDB%20Server%E6%90%AD%E8%BC%89)%20-%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%20(v3.3.5.201801101746)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESEGGER%20J-Link%20(SEGGER%20GDB%20Server%E6%90%AD%E8%BC%89)%20-%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%20(V6.22e_B180108)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%8C%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8D%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%20-%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%BE%E8%B1%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%BB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ES32K14x%20EAR%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20v.0.8.6%20%E7%94%A8%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%9F%20S32%20SDK%E3%80%82SDK%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81SDK%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82S32%20SDK%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ES32K%20SDK%E3%81%AF%3CSTRONG%3E%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%3C%2FSTRONG%3E%E5%88%B6%E9%99%90%E3%82%84%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%3CSTRONG%3E%3C%2FSTRONG%3E%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%3C%2FSTRONG%3ES32K%20SDK%20%E3%81%AF%E3%80%81Windows%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BGreenHills%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20-%20SDK%E3%81%AFGreenHills%20v2014.4%E3%81%A7%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81GreenHills%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81GreenHills%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9v2017.1%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AFGreenHills%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SDK%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESDK%20%E7%AE%A1%E7%90%86%E3%82%92%E5%90%AB%E3%82%80%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EKEA%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcache.nxp.com%252Fdownloads%252Fen%252Fboard-support-packages%252FFRDM-KEA-QSP.zip%253Ffsrch%253D1%2526sr%253D7%2526pageNum%253D3%22%20target%3D%22_blank%22%3E%E7%94%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FA%3E%3C%2FSPAN%3E(%E8%A9%95%E4%BE%A1%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-development-tools%2Ffreemaster-run-time-debugging-tool%3AFREEMASTER%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3C%2FA%3E%20KEA%E3%81%8A%E3%82%88%E3%81%B3S32K%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E7%94%A8%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E9%80%9A%E4%BF%A1%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3EARM%20Cortex-M4%20%E3%82%B3%E3%82%A2%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%20v%3C%2FSTRONG%3E%3CSTRONG%3E%201.1.11%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpages%2Fautomotive-math-and-motor-control-library-set%3AAUTOMATH_MCL%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%20KEA%E3%80%81S32K%E3%80%81%20%E3%81%8A%E3%82%88%E3%81%B3%20S32V234%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%E8%BB%8A%E8%BC%89%E6%95%B0%E5%AD%A6%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E5%8F%AF%E7%94%A8%E6%80%A7%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ECodeWarrior%20for%20MCU%20v.10.6%E3%81%8A%E3%82%88%E3%81%B3Kinetis%20Design%20Studio%E3%81%8B%E3%82%89%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%BE%E8%B1%A1%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EIAR%20v7.x%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3Ev8.11.2%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E3%82%B0%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%92%E3%83%AB%E3%82%BA%20v2017.1.4%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22http%3A%2F%2Fwww.isystem.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EiSystem%3C%2FA%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fwww.lauterbach.com%2Fframes.html%3Fhome.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELauterbach%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.iar.com%2Fiar-embedded-workbench%2Fadd-ons-and-integrations%2Fin-circuit-debugging-probes%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EIAR%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EFreeRTOS%E3%80%81OSEK%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EMQX%204.2%20for%20the%20MAC57D54H%20(%E4%BE%8B%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%BE%E8%B1%A1%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ESKEAZN8%2C%20SKEAZN16%2C%20SKEAZN32%2C%20SKEAZN64%2C%20SKEAZ128%2C%20SKEAZ64%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ES32K144%20v2.0%2C%20S32K142%2C%20S32K146%2C%20S32K148%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ES32V234%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EMAC57D54%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%84%E8%BF%BD%E5%8A%A0%E8%B3%87%E6%96%99%E3%81%AB%E4%B8%80%E5%85%83%E7%9A%84%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%85%A5%E9%96%80%E3%83%9A%E3%83%BC%E3%82%B8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_42.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_42.png%22%20style%3D%22width%3A%20977px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4670i7E849989F250DD04%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_42.png%22%20alt%3D%22pastedImage_42.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_42.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId-1752090101%22%20id%3D%22toc-hId--1620129031%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%90%E3%82%B0%E4%BF%AE%E6%AD%A3%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%A8%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AC%E6%98%8E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AERef%20Manual%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-4629%E3%80%91%E3%80%8CC%2FC%2B%2B%20Build%20-%26gt%3B%20Behavior%E3%80%8D%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%93%8D%E4%BD%9C%E5%BE%8C%E3%81%AB%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-301%E3%80%91%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%BD%9C%E6%A5%AD%E3%81%AE%E5%BE%8C%20(BP%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E5%AE%9F%E8%A1%8C%E3%80%81%E5%86%8D%E9%96%8B%E3%81%AA%E3%81%A9%E3%82%92%E4%BD%BF%E7%94%A8)%E5%88%86%E8%A7%A3%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-1093%E3%80%91%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%85%A8%E4%BD%93%E3%81%8C%201%20%E8%A1%8C%E3%81%AB%E3%81%82%E3%82%8B%E3%83%AB%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%20%22c%22%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-273%E3%80%91%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3D0%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%9D%A1%E4%BB%B6%E4%BB%A5%E9%99%8D%E3%81%AF%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-61%E3%80%91%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E6%B6%88%E3%81%88%E3%82%8B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%20none%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%80%90S32DS-6072%E3%80%91SDK%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%20ProjectInfo.xml%20%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88S32K144%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3ES32%20Design%20Studio%20for%20ARM%202018.R1%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--55364362%22%20id%3D%22toc-hId-867383802%22%3E%3C%2FH2%3E%3CH2%20style%3D%22border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1862818825%22%20id%3D%22toc-hId--940070661%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%23000000%3B%20font-weight%3A%20bold%3B%20font-size%3A%2022px%3B%22%3E%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ES32DS%20for%20ARM%E8%A3%BD%E5%93%81%E3%83%9A%E3%83%BC%E3%82%B8%20-%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fs32-design-studio-ide%2Fs32-design-studio-ide-for-arm-based-mcus%3AS32DS-ARM%3Ftab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FA%3E%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E4%B8%AD%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3ID%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3ID%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%8C%E5%B1%8A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_88.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_88.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F4637i73A5919D96751341%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_88.png%22%20alt%3D%22pastedImage_88.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_88.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2022px%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%22%3ES32%20Design%20Studio%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81S32DS%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AFNXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E8%BF%BD%E8%B7%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211357%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2211462%22%20data-objecttype%3D%2214%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fs32%2Fs32ds%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22font-weight%3A%20400%3B%20height%3A%2024px%3B%20width%3A%20180px%3B%20padding%3A%202pt%203pt%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23d1d1d1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1112289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8CWIN%20XP%E3%81%AE%E5%A4%96%E8%A6%B3%E3%81%A0%E3%81%91%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AEWindows%20XP%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20Real%20Win%20XP%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Windows%20XP%E3%81%AFS32DS%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJiri%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22111.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22111.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F87509i8DA44F068ED6A4BA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22111.JPG%22%20alt%3D%22111.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E111.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%82%B9%E3%82%BF%E3%83%B3%E3%80%81Linux%E3%81%8B%E3%82%89SDK%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E7%90%86%E7%94%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESumit%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E9%80%9A%E3%82%8A%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89SDK%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81Linux%E7%89%88%E3%81%AES32%20Design%20Studio%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B1%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E3%82%A8%E3%82%B9%E3%82%AB%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81S32%20Design%20Studio%E3%81%AELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%ABSDK%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E8%AD%B0%E8%AB%96%E3%81%8C%E4%BF%9D%E7%95%99%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%91%E3%81%84%E5%B0%86%E6%9D%A5(%E4%BB%8A%E5%B9%B4)%E3%81%AB%E3%81%9D%E3%82%8C%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%E3%81%A8%E3%81%AF%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%8A%E3%82%A6%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20-%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%89%8B%E9%A0%86%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340264%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340264%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2218393%22%20data-username%3D%22stanish%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fstanish%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3EStanislav%20Sliva%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20data-dtmassettype%3D%22Download%22%20data-dtmname%3D%22S32%20Design%20Studio%20for%20ARM%C2%AE%202018.R1%20Update%202%20%E2%80%93%20S32K116%20Device%20Support%20%26amp%3B%20S32%20SDK%20EAR%201.8.7%20for%20S32K116%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FS32DS%2FS32DS_ARM_v2018.R1_UP2.zip%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20initial%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32%20Design%20Studio%20for%20ARM%202018.R1%20%E3%81%AE%20(S32%20Design%20Studio%20for%20ARM%C2%AE%202018.R1%20Update%202%20%E2%80%93%20S32K116%20Device%20Support%20%26amp%3B%20S32%20SDK%20EAR%201.8.7%20for%20S32K116%3C%2FA%3E%3CSUP%20style%3D%22font-weight%3A%20400%3B%20font-size%3A%2012px%3B%22%3E(REV%20UP2)%3C%2FSUP%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23b0ca00%20!important%3B%20font-size%3A%2013.7143px%3B%22%3ENEW)%20%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%BD%AE%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2582iCAB0C477BE5632B3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%8D%95%E8%8E%B7.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%3C%2FP%3E%3CP%3E%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81SDK%E3%81%AFWindows%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AE%E3%81%BF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%E5%90%91%E3%81%91%E3%81%AB%E3%81%AF%E3%81%84%E3%81%A4%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ESumit%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A6%E3%82%A7%E3%82%A4%E3%80%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%94%E5%A0%B1%E5%91%8A%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A9%A6%E8%A1%8C%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%2F%E3%82%A6%E3%82%A4%E3%83%AB%E3%82%B9%E5%AF%BE%E7%AD%96%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%80%81%E4%BC%9A%E7%A4%BE%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E9%81%85%E5%BB%B6...%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A8%98%E9%8C%B2%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E4%BB%8A%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B1%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99(%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20style%3D%22width%3A%20593px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7983i6D03FAF65A7A8B52%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E6%97%A0%E6%A0%87%E9%A2%98.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20(Windows%2FLinux)%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ENXP%E3%81%8B%E3%82%89%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E7%90%86%E7%94%B1%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3F%3F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎02-09-2018 06:18 AM
更新者:
