HOWTO: Prepare A SD Card For Linux Boot Of S32V234-EVB Using BSP From VSDK
To prepare an SD card for a Linux boot, it is necessary to connect the SD card to a machine with Linux OS. If a Linux OS machine is not available, then a virtual machine installed to a Windows OS machine may be used.
If you have access to a Linux OS machine, skip to step 4.
Procedure
1) Download and install a virtual machine
2) Download Ubuntu. This tutorial uses the Ubuntu version 14.04.5.  The image will be ubuntu-14.04.5-desktop-amd64.iso.
3) Launch VMware or Virtual Box and create a new virtual machine
Use downloaded Ubuntu image when requested for installer disc image file
Hit Next and select Linux as the guest operating system and select Ubuntu for the version.
Hit Next and name your virtual machine and specify where you want to store it.
Increase the disk size to 40 GB
Hit Finish and install VMware Tools for Linux, if asked
4) Within C:\NXP\S32DS_Vision_v2.0\S32DS\s32v234_sdk\os extract 'build_content.tar.gz', then extract 'build_content.tar' and navigate to the 'v234_linux_build' folder
5) Start virtual machine
May need to manually connect USB-mounted SD card reader
Log in to virtual machine
6) In files, go to 'Home' directory and create a folder "VSDK"
7) Within VSDK folder, copy the files image, u-boot.s32s32v234-evb.dtb, and rootfs.tar from the 'v234_linux_build' folder.
Note: The file s32v234-evb.dtb and u-boot.s32 will have names with XXXXX-suffix for the schematic number printed on the evaluation board (EVB) you are using. Be sure to use the files which correspond to your EVB.
8) Load the card into the reader. If you are using a virtual machine, it is recommended to use a USB adapter instead of a built-in reader in the PC.
9) Within the virtual machine, launch the terminal program
10) Within the terminal program, enter command 'cat /proc/partitions' to view the names of the partitions and identify the names of the partitions on your SD card. Perhaps it is named 'sdb'.
11) Delete all existing partitions.
   a) Enter command 'sudo fdisk /dev/sdb'.
   b) Enter command 'd' and then the number of the partition to delete. Repeat as necessary until all partitions have been deleted
12) Create new partitions
   a) Enter command 'n' for new
   b) Enter 'p' (or just hit <enter>, as this is the default) for primary
   c) Enter '1' (or just hit <enter>, as this is the default) for partition number 1.
   d) Press <enter> to select the default value for the First sector
   e) Enter '+255M' to set the size
   b) Enter command 'n' again, for partition number 2, however, press <enter> to select the default value for the 'Last sector'
13) Set the partition type
   a) Enter command 't' for type
   b) Enter '1' for partition number 1
   c) Enter 'c' for partition type FAT32
   d) Enter command 't' again, for partition number 2, however, enter '83' for partition type LINUX
If you get error 16: Device or resource busy, as shown above, use commands 'umount /dev/sdb1' and 'umount /dev/sdb2' to free the pre-existing partitions.
Then try again and should be ok now
14) Write the new configuration, enter 'w'
15) Try to setup the filesystems. Enter 'sudo mkfs.vfat -n boot /dev/sdb1'. If you get the error '/dev/sdb1 contains a mounted filesystem', you will need to unmount the partition first.
To save time, unmount both /dev/sdb1 and /dev/sdb2. Enter 'umount /dev/sdb1' and then 'umount /dev/sdb2'
Now try 'sudo mkfs.vfat -n boot /dev/sdb1' again
16) It worked, so now enter 'sudo mkfs.ext3 -L rootfs /dev/sdb2'. It will take a minute or two for this to complete. Wait until you get the command prompt again.
17) Now it's time to load the BSP content from the VSDK. But first, change the directory to the one we created earlier for the BSP files. Enter 'cd /home/user/VSDK' or 'cd VSDK'.
Enter the following commands:
sudo dd if=u-boot.s32 of=/dev/sdb bs=512 seek=8 conv=fsync
sudo cp Image /media/user/boot
sudo cp s32v234-evb.dtb /media/user/boot
18) Now we need to extract the root filesystem, change the directory to its location
19) Enter command 'sudo tar -xvf /home/user/VSDK/rootfs.tar'
20) Once the files are extracted, enter command 'sync'
Now the SD card is ready to be used in the S32V234-EVB.
评论
Thanks for the tutorial. I had a doubt from step 17 onwards. It seems one of the steps is missing regarding the mount point.
Hello [email protected]‌,
As the Vision SDK now comes with BSP image provided, this document is no longer necessary to setup your SD card. It is much simpler to just write the image. If the /media/user directory is not existing prior to step 17, then probably it is being created for you when the command sudo cp Image /media/user/boot is issued. Were you not successful in the SD card setup when you completed all of the steps?
Mike
Thanks for the help @Mike Doidge . I was able to follow the instructions and bring up the board!
%3CLINGO-SUB%20id%3D%22lingo-sub-1117839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BD%BF%E7%94%A8%20VSDK%20%E4%B8%AD%E7%9A%84%20BSP%20%E4%B8%BA%20S32V234-EVB%20%E7%9A%84%20Linux%20%E5%90%AF%E5%8A%A8%E5%87%86%E5%A4%87%20SD%20%E5%8D%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%81%E5%87%86%E5%A4%87%E7%94%A8%E4%BA%8E%20Linux%20%E5%90%AF%E5%8A%A8%E7%9A%84%20SD%20%E5%8D%A1%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%20SD%20%E5%8D%A1%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%A3%85%E6%9C%89%20Linux%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9C%BA%E5%99%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%20Linux%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%9C%BA%E5%99%A8%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%AE%89%E8%A3%85%E5%88%B0%20Windows%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%9C%BA%E5%99%A8%E7%9A%84%E8%99%9A%E6%8B%9F%E6%9C%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AE%20Linux%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%9C%BA%E5%99%A8%EF%BC%8C%E8%AF%B7%E8%B7%B3%E8%87%B3%E6%AD%A5%E9%AA%A4%204%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2030px%3B%22%3E%E6%B5%81%E7%A8%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1%EF%BC%89%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%AE%89%E8%A3%85%E8%99%9A%E6%8B%9F%E6%9C%BA%3C%2FP%3E%3CUL%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.vmware.com%2Fproducts%2Fplayer%2Fplayerpro-evaluation.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EVMware%20Workstation%20Player%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.virtualbox.org%2Fwiki%2FDownloads%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%99%9A%E6%8B%9F%E7%9B%92%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20417px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27963i57152D6AF15E12D7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20335px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F28018i6CBD910C0E4A1558%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%EF%BC%89%E4%B8%8B%E8%BD%BD%3CA%20href%3D%22http%3A%2F%2Fwww.ubuntu.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUbuntu%3C%2FA%3E%20%E3%80%82%E6%9C%AC%E6%95%99%E7%A8%8B%E4%BD%BF%E7%94%A8%20Ubuntu%20%E7%89%88%E6%9C%AC%2014.04.5%E3%80%82%E8%AF%A5%E5%9B%BE%E5%83%8F%E5%B0%86%E6%98%AF%3CSTRONG%3Eubuntu-14.04.5-desktop-amd64.iso%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20316px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27943i4FE2AD2D16BD8A05%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3%EF%BC%89%E5%90%AF%E5%8A%A8%20VMware%20%E6%88%96%20Virtual%20Box%20%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E8%99%9A%E6%8B%9F%E6%9C%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20714px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6605i665B9E9C33085281%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%85%89%E7%9B%98%E6%98%A0%E5%83%8F%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%E4%B8%8B%E8%BD%BD%E7%9A%84%20Ubuntu%20%E6%98%A0%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6664iF3DF15D398294E30%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200in%3B%20margin%3A%200in%200in%207.8pt%200in%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200in%3B%20margin%3A%200in%200in%207.8pt%200in%3B%22%3E%E7%82%B9%E5%87%BB%3CSTRONG%3E%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%3C%2FSTRONG%3E%20%EF%BC%8C%E9%80%89%E6%8B%A9%3CSTRONG%3ELinux%3C%2FSTRONG%3E%E4%BD%9C%E4%B8%BA%E5%AE%A2%E6%88%B7%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%B9%B6%E9%80%89%E6%8B%A9%20Ubuntu%20%E4%BD%9C%E4%B8%BA%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29223iEB2378E5D65ECBB4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E7%82%B9%E5%87%BB%3CSTRONG%3E%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%3C%2FSTRONG%3E%E5%B9%B6%E5%91%BD%E5%90%8D%E6%82%A8%E7%9A%84%E8%99%9A%E6%8B%9F%E6%9C%BA%E5%B9%B6%E6%8C%87%E5%AE%9A%E6%82%A8%E6%83%B3%E8%A6%81%E5%AD%98%E5%82%A8%E5%AE%83%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31108i767423C5397A919B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%86%E7%A3%81%E7%9B%98%E5%A4%A7%E5%B0%8F%E5%A2%9E%E5%8A%A0%E5%88%B0%2040%20GB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6709i615B7FFE8E3736A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%A6%82%E6%9E%9C%E7%B3%BB%E7%BB%9F%E8%AF%A2%E9%97%AE%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%3CSTRONG%3E%E2%80%9C%E5%AE%8C%E6%88%90%E2%80%9D%3C%2FSTRONG%3E%E5%B9%B6%E5%AE%89%E8%A3%85%E9%80%82%E7%94%A8%E4%BA%8E%20Linux%20%E7%9A%84%20VMware%20Tools%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29314i704E2BEF5552F602%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20306px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6751iC1E4FAC5FDE866A4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%EF%BC%89%E5%9C%A8C%3A%5CNXP%5CS32DS_Vision_v2.0%5CS32DS%5Cs32v234_sdk%5Cos%E4%B8%AD%E6%8F%90%E5%8F%96%E2%80%9C%20%3CSTRONG%3Ebuild_content.tar.gz%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8F%90%E5%8F%96%E2%80%9C%20%3CSTRONG%3Ebuild_content.tar%3C%2FSTRONG%3E%20%E2%80%9D%E5%B9%B6%E5%AF%BC%E8%88%AA%E5%88%B0%E2%80%9C%20%3CSTRONG%3Ev234_linux_build%3C%2FSTRONG%3E%20%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20984px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F30594i15CE68A648A1EB51%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5%EF%BC%89%E5%90%AF%E5%8A%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20714px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6776i7E2EB04FF67DAE66%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E6%89%8B%E5%8A%A8%E8%BF%9E%E6%8E%A5%20USB%20%E6%8E%A5%E5%8F%A3%E7%9A%84%20SD%20%E5%8D%A1%E8%AF%BB%E5%8D%A1%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20364px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6847iD415B202C7461DB5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%99%BB%E5%BD%95%E8%99%9A%E6%8B%9F%E6%9C%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20816px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6896i10C1DF200330B536%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6%EF%BC%89%E5%9C%A8%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E8%BD%AC%E5%88%B0%E2%80%9CHome%E2%80%9D%E7%9B%AE%E5%BD%95%E5%B9%B6%E5%88%9B%E5%BB%BA%E6%96%87%E4%BB%B6%E5%A4%B9%E2%80%9CVSDK%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6933i0B07907BA78F4BDF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E7%EF%BC%89%E5%9C%A8VSDK%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%3CSTRONG%3Eimage%3C%2FSTRONG%3E%20%E3%80%81%20%3CSTRONG%3Eu-boot.s32%3C%2FSTRONG%3E%20%E3%80%81%3CSTRONG%3Es32v234-evb.dtb%3C%2FSTRONG%3E%20%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%9D%A5%E8%87%AA%E2%80%98v234_linux_build%E2%80%99%E6%96%87%E4%BB%B6%E5%A4%B9%E7%9A%84%3CSTRONG%3Erootfs.tar%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200in%3B%20text-indent%3A%20-17.25pt%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%20s32v234-evb.dtb%20%E5%92%8C%20u-boot.s32%20%E7%9A%84%E5%90%8D%E7%A7%B0%E5%B0%86%E5%B8%A6%E6%9C%89%20XXXXX%20%E5%90%8E%E7%BC%80%EF%BC%8C%E8%AF%A5%E5%90%8E%E7%BC%80%E4%BB%A3%E8%A1%A8%E6%82%A8%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E8%AF%84%E4%BC%B0%E6%9D%BF%20(EVB)%20%E4%B8%8A%E5%8D%B0%E5%88%B7%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%E7%BC%96%E5%8F%B7%E3%80%82%E7%A1%AE%E4%BF%9D%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%82%A8%E7%9A%84%20EVB%20%E7%9B%B8%E5%AF%B9%E5%BA%94%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20655px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29356iB01D7975D30F48C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E8%EF%BC%89%E5%B0%86%E5%8D%A1%E8%A3%85%E5%85%A5%E8%AF%BB%E5%8D%A1%E5%99%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E8%99%9A%E6%8B%9F%E6%9C%BA%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20USB%20%E9%80%82%E9%85%8D%E5%99%A8%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20PC%20%E5%86%85%E7%BD%AE%E7%9A%84%E8%AF%BB%E5%8D%A1%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20894px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7016i4C7D76B0E94D3731%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E9%EF%BC%89%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E4%B8%AD%EF%BC%8C%E5%90%AF%E5%8A%A8%E7%BB%88%E7%AB%AF%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7064iE93CF6DB9F5B510C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E10%EF%BC%89%E5%9C%A8%E7%BB%88%E7%AB%AF%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3Ecat%20%2Fproc%2Fpartitions%3C%2FSTRONG%3E%20%E2%80%9D%E6%9F%A5%E7%9C%8B%E5%88%86%E5%8C%BA%E5%90%8D%E7%A7%B0%E5%B9%B6%E8%AF%86%E5%88%AB%20SD%20%E5%8D%A1%E4%B8%8A%E5%88%86%E5%8C%BA%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%E4%B9%9F%E8%AE%B8%E5%AE%83%E8%A2%AB%E5%91%BD%E5%90%8D%E4%B8%BA%E2%80%98%20%3CSTRONG%3Esdb%3C%2FSTRONG%3E%20%E2%80%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7061i1D21000C7F195DA6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E11%EF%BC%89%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%E7%8E%B0%E6%9C%89%E5%88%86%E5%8C%BA%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Ba)%20Enter%20command%20'%3CSTRONG%3Esudo%20fdisk%20%2Fdev%2Fsdb%3C%2FSTRONG%3E'.%3C%2FP%3E%3CP%3Eb%EF%BC%89%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3Ed%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BE%93%E5%85%A5%E8%A6%81%E5%88%A0%E9%99%A4%E7%9A%84%E5%88%86%E5%8C%BA%E5%8F%B7%E3%80%82%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E9%87%8D%E5%A4%8D%E6%93%8D%E4%BD%9C%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%89%80%E6%9C%89%E5%88%86%E5%8C%BA%E9%83%BD%E8%A2%AB%E5%88%A0%E9%99%A4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7137i9381B5C1FF9F9E08%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_15.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E12%EF%BC%89%E5%88%9B%E5%BB%BA%E6%96%B0%E5%88%86%E5%8C%BA%3C%2FP%3E%3CP%3Ea)%20%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%98%20%3CSTRONG%3En%3C%2FSTRONG%3E%20%E2%80%99%E8%A1%A8%E7%A4%BA%E6%96%B0%E5%BB%BA%3C%2FP%3E%3CP%3Eb)%20%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Ep%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%88%E6%88%96%E7%9B%B4%E6%8E%A5%E6%8C%89%20%3CENTER%3E%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E6%98%AF%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%E4%BD%9C%E4%B8%BA%E4%B8%BB%E8%A6%81%3C%2FENTER%3E%3C%2FP%3E%3CP%3Ec)%20%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3E1%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%88%E6%88%96%E7%9B%B4%E6%8E%A5%E6%8C%89%20%3CENTER%3E%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E6%98%AF%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%E4%BD%9C%E4%B8%BA%E5%88%86%E5%8C%BA%E5%8F%B7%201%E3%80%82%3C%2FENTER%3E%3C%2FP%3E%3CP%3Ed)%20%E6%8C%89%20%3CENTER%3E%20%E9%94%AE%E9%80%89%E6%8B%A9%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%89%87%E5%8C%BA%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%3C%2FENTER%3E%3C%2FP%3E%3CP%3Ee)%20%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3E%2B255M%3C%2FSTRONG%3E%20%E2%80%9D%E8%AE%BE%E7%BD%AE%E5%A4%A7%E5%B0%8F%3C%2FP%3E%3CP%3Eb)%20%E5%86%8D%E6%AC%A1%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3En%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%8C%E5%AF%B9%E4%BA%8E%E5%88%86%E5%8C%BA%E5%8F%B7%202%EF%BC%8C%E6%8C%89%20%3CENTER%3E%20%E9%80%89%E6%8B%A9%E2%80%9C%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E6%89%87%E5%8C%BA%E2%80%9D%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%3C%2FENTER%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20855px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6727i7D8E671F901F2EFC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E13%EF%BC%89%E8%AE%BE%E7%BD%AE%E5%88%86%E5%8C%BA%E7%B1%BB%E5%9E%8B%3C%2FP%3E%3CP%3Ea)%20%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3Et%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3Eb)%20%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3E1%3C%2FSTRONG%3E%20%E2%80%9D%E4%BD%9C%E4%B8%BA%E5%88%86%E5%8C%BA%E5%8F%B7%201%3C%2FP%3E%3CP%3Ec)%20%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Ec%3C%2FSTRONG%3E%20%E2%80%9D%E8%A1%A8%E7%A4%BA%E5%88%86%E5%8C%BA%E7%B1%BB%E5%9E%8B%E4%B8%BAFAT32%3C%2FP%3E%3CP%3Ed)%20%E5%86%8D%E6%AC%A1%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%20'%20%3CSTRONG%3Et%3C%2FSTRONG%3E%20'%EF%BC%8C%E5%AF%B9%E4%BA%8E%E5%88%86%E5%8C%BA%E5%8F%B7%202%EF%BC%8C%E8%BE%93%E5%85%A5%20'%20%3CSTRONG%3E83%3C%2FSTRONG%3E%20'%20%E8%A1%A8%E7%A4%BA%E5%88%86%E5%8C%BA%E7%B1%BB%E5%9E%8B%E4%B8%BA%20LINUX%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%20style%3D%22width%3A%20855px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7195i5B24B05C0016C9FF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.png%22%20alt%3D%22pastedImage_17.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_17.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%2016%EF%BC%9A%E8%AE%BE%E5%A4%87%E6%88%96%E8%B5%84%E6%BA%90%E7%B9%81%E5%BF%99%EF%BC%8C%E5%A6%82%E4%B8%8A%E6%89%80%E7%A4%BA%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3Eumount%20%2Fdev%2Fsdb1%3C%2FSTRONG%3E%20%E2%80%9D%E5%92%8C%E2%80%9C%20%3CSTRONG%3Eumount%20%2Fdev%2Fsdb2%3C%2FSTRONG%3E%20%E2%80%9D%E9%87%8A%E6%94%BE%E9%A2%84%E5%85%88%E5%AD%98%E5%9C%A8%E7%9A%84%E5%88%86%E5%8C%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20855px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6602i69A8EA5421FA09AB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E4%BA%86%3C%2FP%3E%3CP%3E14%EF%BC%89%E5%86%99%E5%85%A5%E6%96%B0%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Ew%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20855px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7583i6F2D4FA6321F3D2E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E15%EF%BC%89%E5%B0%9D%E8%AF%95%E8%AE%BE%E7%BD%AE%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Esudo%20mkfs.vfat%20-n%20boot%20%2Fdev%2Fsdb1%3C%2FSTRONG%3E%20%E2%80%9D%E3%80%82%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E2%80%9C%2Fdev%2Fsdb1%20%E5%8C%85%E5%90%AB%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E2%80%9D%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%85%88%E5%8D%B8%E8%BD%BD%E8%AF%A5%E5%88%86%E5%8C%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20728px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7634i3C1B9756BD2E236D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E8%8A%82%E7%9C%81%E6%97%B6%E9%97%B4%EF%BC%8C%E8%AF%B7%E5%8D%B8%E8%BD%BD%20%2Fdev%2Fsdb1%20%E5%92%8C%20%2Fdev%2Fsdb2%E3%80%82%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Eumount%20%2Fdev%2Fsdb1%3C%2FSTRONG%3E%20%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Eumount%20%2Fdev%2Fsdb2%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7682i42EBB195739186E8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E2%80%9C%20%3CSTRONG%3Esudo%20mkfs.vfat%20-n%20boot%20%2Fdev%2Fsdb1%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20727px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7734i621BCC27D38A2058%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E16)%20%E5%AE%83%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86%EF%BC%8C%E6%89%80%E4%BB%A5%E7%8E%B0%E5%9C%A8%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Esudo%20mkfs.ext3%20-L%20rootfs%20%2Fdev%2Fsdb2%3C%2FSTRONG%3E%20%E2%80%9D%E3%80%82%E5%AE%8C%E6%88%90%E6%AD%A4%E6%93%8D%E4%BD%9C%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%A4%E5%88%86%E9%92%9F%E3%80%82%E7%AD%89%E5%88%B0%E5%86%8D%E6%AC%A1%E6%94%B6%E5%88%B0%E5%91%BD%E4%BB%A4%E6%8F%90%E7%A4%BA%E7%AC%A6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7779iCDD32C552D6EAFA0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E17%EF%BC%89%E7%8E%B0%E5%9C%A8%E6%98%AF%E6%97%B6%E5%80%99%E4%BB%8E%20VSDK%20%E5%8A%A0%E8%BD%BD%20BSP%20%E5%86%85%E5%AE%B9%E4%BA%86%E3%80%82%E4%BD%86%E9%A6%96%E5%85%88%EF%BC%8C%E5%B0%86%E7%9B%AE%E5%BD%95%E6%9B%B4%E6%94%B9%E4%B8%BA%E6%88%91%E4%BB%AC%E4%B9%8B%E5%89%8D%E4%B8%BA%20BSP%20%E6%96%87%E4%BB%B6%E5%88%9B%E5%BB%BA%E7%9A%84%E7%9B%AE%E5%BD%95%E3%80%82%E8%BE%93%E5%85%A5%E2%80%9C%20%3CSTRONG%3Ecd%20%2Fhome%2Fuser%2FVSDK%3C%2FSTRONG%3E%20%E2%80%9D%E6%88%96%E2%80%9C%20%3CSTRONG%3Ecd%20VSDK%3C%2FSTRONG%3E%20%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20217px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7536i8D5167F7D3A27C45%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3Esudo%20dd%20if%3Du-boot.s32%20of%3D%2Fdev%2Fsdb%20bs%3D512%20seek%3D8%20conv%3Dfsync%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Esudo%20cp%20Image%20%2Fmedia%2Fuser%2Fboot%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Esudo%20cp%20s32v234-evb.dtb%20%2Fmedia%2Fuser%2Fboot%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7825iC3C544D8B869CF3F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E18%EF%BC%89%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%8F%90%E5%8F%96%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%B0%86%E7%9B%AE%E5%BD%95%E6%9B%B4%E6%94%B9%E4%B8%BA%E5%85%B6%E4%BD%8D%E7%BD%AE%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%20style%3D%22width%3A%20401px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7346i1FCECEA24DFC8939%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_27.png%22%20alt%3D%22pastedImage_27.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_27.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E19)%20%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%20'%20%3CSTRONG%3Esudo%20tar%20-xvf%20%2Fhome%2Fuser%2FVSDK%2Frootfs.tar%3C%2FSTRONG%3E%20'%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_28.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_28.png%22%20style%3D%22width%3A%20736px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7442i998AF918940CAF6B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_28.png%22%20alt%3D%22pastedImage_28.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_28.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E20%EF%BC%89%E6%96%87%E4%BB%B6%E6%8F%90%E5%8F%96%E5%90%8E%EF%BC%8C%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E2%80%9C%20%3CSTRONG%3Esync%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%20style%3D%22width%3A%20377px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F7494i7D4CCD85AB8FCF14%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_29.png%22%20alt%3D%22pastedImage_29.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_29.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%20SD%20%E5%8D%A1%E5%B7%B2%E5%87%86%E5%A4%87%E5%A5%BD%E5%9C%A8%20S32V234-EVB%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BD%BF%E7%94%A8%20VSDK%20%E4%B8%AD%E7%9A%84%20BSP%20%E4%B8%BA%20S32V234-EVB%20%E7%9A%84%20Linux%20%E5%90%AF%E5%8A%A8%E5%87%86%E5%A4%87%20SD%20%E5%8D%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%40Mike%20Doidge%20%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E8%83%BD%E5%A4%9F%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E6%93%8D%E4%BD%9C%E5%B9%B6%E8%B0%83%E5%87%BA%E4%B8%BB%E6%9D%BF%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BD%BF%E7%94%A8%20VSDK%20%E4%B8%AD%E7%9A%84%20BSP%20%E4%B8%BA%20S32V234-EVB%20%E7%9A%84%20Linux%20%E5%90%AF%E5%8A%A8%E5%87%86%E5%A4%87%20SD%20%E5%8D%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdakshina.dasari%40gmail.com%22%20target%3D%22_blank%22%3Edakshina.dasari%40gmail.com%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20Vision%20SDK%20%E7%8E%B0%E5%9C%A8%E9%99%84%E5%B8%A6%E4%BA%86%20BSP%20%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%86%8D%E9%9C%80%E8%A6%81%E6%AD%A4%E6%96%87%E6%A1%A3%E6%9D%A5%E8%AE%BE%E7%BD%AE%E6%82%A8%E7%9A%84%20SD%20%E5%8D%A1%E3%80%82%E5%8F%AA%E9%9C%80%E5%86%99%E5%85%A5%E5%9B%BE%E5%83%8F%E5%B0%B1%E7%AE%80%E5%8D%95%E5%A4%9A%E4%BA%86%E3%80%82%E5%A6%82%E6%9E%9C%20%2Fmedia%2Fuser%20%E7%9B%AE%E5%BD%95%E5%9C%A8%E6%AD%A5%E9%AA%A4%2017%20%E4%B9%8B%E5%89%8D%E4%B8%8D%E5%AD%98%E5%9C%A8%EF%BC%8C%E9%82%A3%E4%B9%88%E5%9C%A8%E5%8F%91%E5%87%BA%E5%91%BD%E4%BB%A4%3CSTRONG%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3Esudo%20cp%20Image%20%2Fmedia%2Fuser%2Fboot%3C%2FSTRONG%3E%E6%97%B6%E5%8F%AF%E8%83%BD%E4%BC%9A%E4%B8%BA%E6%82%A8%E5%88%9B%E5%BB%BA%E8%AF%A5%E7%9B%AE%E5%BD%95%E3%80%82%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%E5%90%8E%EF%BC%8CSD%20%E5%8D%A1%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E6%9C%AA%E6%88%90%E5%8A%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%EF%BC%9A%E4%BD%BF%E7%94%A8%20VSDK%20%E4%B8%AD%E7%9A%84%20BSP%20%E4%B8%BA%20S32V234-EVB%20%E7%9A%84%20Linux%20%E5%90%AF%E5%8A%A8%E5%87%86%E5%A4%87%20SD%20%E5%8D%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%95%99%E7%A8%8B%E3%80%82%E4%BB%8E%E7%AC%AC%2017%20%E6%AD%A5%E5%BC%80%E5%A7%8B%E6%88%91%E5%B0%B1%E6%9C%89%E7%96%91%E9%97%AE%E4%BA%86%E3%80%82%E4%BC%BC%E4%B9%8E%E7%BC%BA%E5%B0%91%E6%9C%89%E5%85%B3%E6%8C%82%E8%BD%BD%E7%82%B9%E7%9A%84%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-19-2017 02:22 PM
更新人:
