HOWTO: Install GHS Compiler Plugin
S32 Design Studio (S32DS) supports Eclipse plug-in of Green Hills Software (GHS) compiler to compile S32DS projects via GHS compiler. This document describes how to install this plug-in and enable GHS in the new project wizard.
After the GHS Eclipse plug-in is installed successfully, you can be able to create and build S32DS project using GHS compiler under S32DS Eclipse environment if the device and SDKs support GHS compiler.
Installation instructions
To able to use GHS compiler, you need to make sure that GHS compiler is installed with a valid license. Follow the steps below to install eclipse plugin:
Install GHS Eclipse plug-in
  • On S32DS graphical user interface, go to menu "Help" -> "Install New Software"
In the "Install" dialog appears, click on "Add" button. In the "Add Repository" dialogappears, click on "Local". Navigate to the eclipse directory located in your MULTI compiler installation(eg: C:\ghs\comp_202114\eclipse)
In the Name box, enter "GHS Eclipse". Click on "Add" button.
 In the Name/Version list, expand the Green Hills MULTI for Eclipse item. Select GreenHills MULTI for Eclipse corresponding to your target architecture(eg: Green Hills MULTI for Eclipse(ARM) and Green Hills MULTI for Eclipse(ARM64)). If you have MULTI licenses for more than one architecture, you can select all the targets you are licensed for. Click Next until you see the license acceptance page.
 If you accept the terms of the feature license, select I accept the terms in the license agreement. And click on "Finish" button.
If the Security Warning window appears, click on "Install anyway".
In the "Software Updates" dialog box appears, click on "Restart Now" to restart S32DS.- Go to "Window" -> select "Preference" -> "S32 Design Studio for S32 Platform" -> "S32DS Variables". Set your GHS installation path for S32DS_GHS_PATH variable (ex "C:\ghs\comp_202114").
Create new S32DS project using GHS in the project wizard.
Now you can create a new S32DS project and select GHS toolchain for the device andSDKs support GHS toolchain.
And you can see the GHS settings are showed in the S32DS project properties.
コメント
Hello NXP team,
I have tried the above procedure and its not working, It is a simple test project.
Created a simple project, using pins tool, updated the code , and tried to build all.
here is the commander and linker options generated with new project.
GHS C Compiler for ARM Standalone-
ccarm
Options-
-preprocess_assembly_files -list --no_slash_comment -C99 --no_exceptions --gnu_asm --unsigned_fields --unsigned_chars --no_short_enum --ghstd=last --prototype_errors -Wimplicit-int --incorrect_pragma_warnings -Wshadow -Wtrigraphs -Wundef -G -dwarf2 -Osize -DS32K344 -DGHS -DENABLE_FPU -DMPU_ENABLE -DI_CACHE_ENABLE -DD_CACHE_ENABLE -DCPU_S32K344 -DS32K3XX -DCPU_CORTEX_M7 -IC:\Users\ganheg1\workspaceS32DS.3.5\GHS_Test/generate/include -IC:\Users\ganheg1\workspaceS32DS.3.5\GHS_Test/RTD/include -I"C:\NXP\S32DS.3.5\eclipse\../S32DS/software/PlatformSDK_S32K3/RTD/BaseNXP_TS_T40D34M30I0R0/header" -I"C:\NXP\S32DS.3.5\eclipse\/../S32DS/software/PlatformSDK_S32K3/RTD/BaseNXP_TS_T40D34M30I0R0//header/" -I"C:\NXP\S32DS.3.5\eclipse\/../S32DS/software/PlatformSDK_S32K3/RTD/BaseNXP_TS_T40D34M30I0R0//include/" -I"C:\NXP\S32DS.3.5\eclipse\/../S32DS/software/PlatformSDK_S32K3/RTD/Platform_TS_T40D34M30I0R0//include/" -I"C:\NXP\S32DS.3.5\eclipse\/../S32DS/software/PlatformSDK_S32K3/RTD/Platform_TS_T40D34M30I0R0//startup/include/" -I"C:\Users\ganheg1\workspaceS32DS.3.5\GHS_Test/board" -keeptempfiles -littleendian -cpu=cortexm7 -fpu=vfpv5_d16 -fsingle -thumb --no_commons
GHS C Linker for ARM Standalone
ccarm
options -
--gnu_asm -g -dwarf2 -Wl,-keep=C40_Ip_AccessCode -Wl,-v -T "C:\Users\ganheg1\workspaceS32DS.3.5\GHS_Test/Project_Settings/Linker_Files/linker_flash_s32k344.ld" -e Reset_Handler -delete -ignore_debug_references -map -keepmap -Mn -nostartfiles -I"C:\Users\ganheg1\workspaceS32DS.3.5\GHS_Test/board" -larch -lstartup -lind_sd -L"C:\ghs\comp_202354_1fp_x64_ForNXP\lib\thumb2" -cpu=cortexm7 -thumb
%3CLINGO-SUB%20id%3D%22lingo-sub-1436232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHOWTO%3A%20GHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%BB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1436232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3ES32%20Design%20Studio%EF%BC%88S32DS%EF%BC%89%E3%81%AF%E3%80%81Green%20Hills%20Software%EF%BC%88GHS%EF%BC%89%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AEEclipse%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81GHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6S32DS%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A8%E3%80%81%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%BB%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7GHS%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EGHS%20Eclipse%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%20SDK%20%E3%81%8C%20GHS%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81S32DS%20Eclipse%20%E7%92%B0%E5%A2%83%E3%81%A7%20GHS%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20S32DS%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%89%8B%E9%A0%86%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EGHS%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%A7%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Eclipse%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1327627605%22%20id%3D%22toc-hId--493836973%22%3E%3CFONT%20size%3D%224%22%3EGHS%20Eclipse%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FFONT%3E%3C%2FH2%3E%0A%3CUL%3E%0A%3CLI%3ES32DS%E3%81%AE%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E3%83%BB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%80%81%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%E3%80%8CHelp%EF%BC%88%E3%83%98%E3%83%AB%E3%83%97%EF%BC%89%E3%80%8D-%26gt%3B%E3%80%8CInstall%20New%20Software%EF%BC%88%E6%96%B0%E8%A6%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%EF%BC%89%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_0-1724323738892.jpeg%22%20style%3D%22width%3A%20525px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_0-1724323738892.jpeg%22%20style%3D%22width%3A%20525px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294765i9CAD41D61A7A0F44%2Fimage-dimensions%2F525x200%3Fv%3Dv2%22%20width%3D%22525%22%20height%3D%22200%22%20role%3D%22button%22%20title%3D%22DanielBarbu_0-1724323738892.jpeg%22%20alt%3D%22DanielBarbu_0-1724323738892.jpeg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_0-1724323738892.jpeg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8CInstall%EF%BC%88%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%EF%BC%89%E3%80%8D%E3%83%80%E3%82%A4%E3%82%A2%E3%83%AD%E3%82%B0%E3%81%A7%E3%80%81%E3%80%8CAdd%EF%BC%88%E8%BF%BD%E5%8A%A0%EF%BC%89%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8CAdd%20Repository%EF%BC%88%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%EF%BC%89%E3%80%8D%E3%83%80%E3%82%A4%E3%82%A2%E3%83%AD%E3%82%B0%E3%81%A7%E3%80%81%E3%80%8CLocal%EF%BC%88%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%EF%BC%89%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MULTI%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%85%88%E3%81%AB%E3%81%82%E3%82%8Beclipse%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%EF%BC%9A%20C%3A%5Cghs%5Ccomp_202114%5Ceclipse%EF%BC%89%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_1-1724323981927.png%22%20style%3D%22width%3A%20529px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_1-1724323981927.png%22%20style%3D%22width%3A%20529px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294769iA10672ED84707A86%2Fimage-dimensions%2F529x370%3Fv%3Dv2%22%20width%3D%22529%22%20height%3D%22370%22%20role%3D%22button%22%20title%3D%22DanielBarbu_1-1724323981927.png%22%20alt%3D%22DanielBarbu_1-1724323981927.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_1-1724323981927.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%E3%80%8CName%EF%BC%88%E5%90%8D%E5%89%8D%EF%BC%89%E3%80%8D%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%80%8CGHS%20Eclipse%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CAdd%EF%BC%88%E8%BF%BD%E5%8A%A0%EF%BC%89%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_2-1724324072313.png%22%20style%3D%22width%3A%20526px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_2-1724324072313.png%22%20style%3D%22width%3A%20526px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294770iBFB820514507EED6%2Fimage-dimensions%2F526x190%3Fv%3Dv2%22%20width%3D%22526%22%20height%3D%22190%22%20role%3D%22button%22%20title%3D%22DanielBarbu_2-1724324072313.png%22%20alt%3D%22DanielBarbu_2-1724324072313.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_2-1724324072313.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%E5%90%8D%E5%89%8D%2F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%80%81Green%20Hills%20MULTI%20for%20Eclipse%E3%81%AE%E9%A0%85%E7%9B%AE%E3%82%92%E5%B1%95%E9%96%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E5%90%88%E8%87%B4%E3%81%99%E3%82%8BGreen%20Hills%20MULTI%20for%20Eclipse%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%EF%BC%9AGreen%20Hills%20MULTI%20for%20Eclipse%EF%BC%88ARM%EF%BC%89%E3%81%A8Green%20Hills%20MULTI%20for%20Eclipse%EF%BC%88ARM64%EF%BC%89%EF%BC%89%E3%80%82%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6MULTI%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%92%E4%BF%9D%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CNext%EF%BC%88%E6%AC%A1%E3%81%B8%EF%BC%89%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E5%90%8C%E6%84%8F%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%BE%E3%81%A7%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_3-1724324146518.png%22%20style%3D%22width%3A%20505px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_3-1724324146518.png%22%20style%3D%22width%3A%20505px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294772i44C9630E51BB8053%2Fimage-dimensions%2F505x350%3Fv%3Dv2%22%20width%3D%22505%22%20height%3D%22350%22%20role%3D%22button%22%20title%3D%22DanielBarbu_3-1724324146518.png%22%20alt%3D%22DanielBarbu_3-1724324146518.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_3-1724324146518.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3E%E6%A9%9F%E8%83%BD%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CI%20accept%20the%20terms%20in%20the%20license%20agreement%EF%BC%88%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CFinish%EF%BC%88%E5%AE%8C%E4%BA%86%EF%BC%89%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_4-1724324257519.png%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_4-1724324257519.png%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294774iC2B7F6816E2C6C9C%2Fimage-dimensions%2F500x325%3Fv%3Dv2%22%20width%3D%22500%22%20height%3D%22325%22%20role%3D%22button%22%20title%3D%22DanielBarbu_4-1724324257519.png%22%20alt%3D%22DanielBarbu_4-1724324257519.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_4-1724324257519.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%AD%A6%E5%91%8A%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CInstall%20anyway%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_5-1724324310392.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_5-1724324310392.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294775iF05C4249ED31E723%2Fimage-dimensions%2F507x190%3Fv%3Dv2%22%20width%3D%22507%22%20height%3D%22190%22%20role%3D%22button%22%20title%3D%22DanielBarbu_5-1724324310392.png%22%20alt%3D%22DanielBarbu_5-1724324310392.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_5-1724324310392.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8CSoftware%20Updates%EF%BC%88%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%EF%BC%89%E3%80%8D%E3%83%80%E3%82%A4%E3%82%A2%E3%83%AD%E3%82%B0%E3%83%BB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A7%E3%80%81%E3%80%8CRestart%20Now%EF%BC%88%E4%BB%8A%E3%81%99%E3%81%90%E5%86%8D%E8%B5%B7%E5%8B%95%EF%BC%89%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81S32DS%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CWindow%EF%BC%88%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%EF%BC%89%E3%80%8D-%26gt%3B%E3%80%8CPreference%EF%BC%88%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%EF%BC%89%E3%80%8D-%26gt%3B%E3%80%8CS32%20Design%20Studio%20for%20S32%20Platform%E3%80%8D-%26gt%3B%E3%80%8CS32DS%20Variables%EF%BC%88S32DS%E5%A4%89%E6%95%B0%EF%BC%89%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82S32DS_GHS_PATH%E5%A4%89%E6%95%B0%E3%81%ABGHS%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%91%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E4%BE%8B%EF%BC%9A%E3%80%8CC%3A%5Cghs%5Ccomp_202114%E3%80%8D%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_6-1724324374973.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_6-1724324374973.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294776iE9F34786F472CFE6%2Fimage-dimensions%2F507x360%3Fv%3Dv2%22%20width%3D%22507%22%20height%3D%22360%22%20role%3D%22button%22%20title%3D%22DanielBarbu_6-1724324374973.png%22%20alt%3D%22DanielBarbu_6-1724324374973.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_6-1724324374973.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7GHS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84S32DS%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%86%E3%81%97%E3%81%A6%E3%80%81GHS%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81S32DS%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81GHS%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_7-1724324414370.png%22%20style%3D%22width%3A%20498px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_7-1724324414370.png%22%20style%3D%22width%3A%20498px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294777i486078AEAE778BF8%2Fimage-dimensions%2F498x360%3Fv%3Dv2%22%20width%3D%22498%22%20height%3D%22360%22%20role%3D%22button%22%20title%3D%22DanielBarbu_7-1724324414370.png%22%20alt%3D%22DanielBarbu_7-1724324414370.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_7-1724324414370.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%94%BB%E9%9D%A2%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81S32DS%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%ABGHS%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielBarbu_8-1724324493234.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielBarbu_8-1724324493234.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294778i554122344E998812%2Fimage-dimensions%2F507x240%3Fv%3Dv2%22%20width%3D%22507%22%20height%3D%22240%22%20role%3D%22button%22%20title%3D%22DanielBarbu_8-1724324493234.png%22%20alt%3D%22DanielBarbu_8-1724324493234.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielBarbu_8-1724324493234.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1943735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HOWTO%3A%20GHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%BB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%83%BB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E8%A6%8F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EGHS%20C%20ARM%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E7%94%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eccarm%3C%2FP%3E%3CP%3EOptions-%3C%2FP%3E%3CP%3E-preprocess_assembly_files%20-list%20--no_slash_comment%20-C99%20--no_exceptions%20--gnu_asm%20--unsigned_fields%20--unsigned_chars%20--no_short_enum%20--ghstd%3Dlast%20--prototype_errors%20-Wimplicit-int%20--incorrect_pragma_warnings%20-Wshadow%20-Wtrigraphs%20-Wundef%20-G%20-dwarf2%20-Osize%20-DS32K344%20-DGHS%20-DENABLE_FPU%20-DMPU_ENABLE%20-DI_CACHE_ENABLE%20-DD_CACHE_ENABLE%20-DCPU_S32K344%20-DS32K3XX%20-DCPU_CORTEX_M7%20-IC%3A%5CUsers%5Cganheg1%5CworkspaceS32DS.3.5%5CGHS_Test%2Fgenerate%2Finclude%20-IC%3A%5CUsers%5Cganheg1%5CworkspaceS32DS.3.5%5CGHS_Test%2FRTD%2Finclude%20-I%22C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5C..%2FS32DS%2Fsoftware%2FPlatformSDK_S32K3%2FRTD%2FBaseNXP_TS_T40D34M30I0R0%2Fheader%22%20-I%22C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5C%2F..%2FS32DS%2Fsoftware%2FPlatformSDK_S32K3%2FRTD%2FBaseNXP_TS_T40D34M30I0R0%2F%2Fheader%2F%22%20-I%22C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5C%2F..%2FS32DS%2Fsoftware%2FPlatformSDK_S32K3%2FRTD%2FBaseNXP_TS_T40D34M30I0R0%2F%2Finclude%2F%22%20-I%22C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5C%2F..%2FS32DS%2Fsoftware%2FPlatformSDK_S32K3%2FRTD%2FPlatform_TS_T40D34M30I0R0%2F%2Finclude%2F%22%20-I%22C%3A%5CNXP%5CS32DS.3.5%5Ceclipse%5C%2F..%2FS32DS%2Fsoftware%2FPlatformSDK_S32K3%2FRTD%2FPlatform_TS_T40D34M30I0R0%2F%2Fstartup%2Finclude%2F%22%20-I%22C%3A%5CUsers%5Cganheg1%5CworkspaceS32DS.3.5%5CGHS_Test%2Fboard%22%20-keeptempfiles%20-littleendian%20-cpu%3Dcortexm7%20-fpu%3Dvfpv5_d16%20-fsingle%20-thumb%20--no_commons%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EGHS%20C%20ARM%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E7%94%A8%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eccarm%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20-%3C%2FP%3E%3CP%3E--gnu_asm%20-g%20-dwarf2%20-Wl%2C-keep%3DC40_Ip_AccessCode%20-Wl%2C-v%20-T%20%22C%3A%5CUsers%5Cganheg1%5CworkspaceS32DS.3.5%5CGHS_Test%2FProject_Settings%2FLinker_Files%2Flinker_flash_s32k344.ld%22%20-e%20Reset_Handler%20-delete%20-ignore_debug_references%20-map%20-keepmap%20-Mn%20-nostartfiles%20-I%22C%3A%5CUsers%5Cganheg1%5CworkspaceS32DS.3.5%5CGHS_Test%2Fboard%22%20-larch%20-lstartup%20-lind_sd%20-L%22C%3A%5Cghs%5Ccomp_202354_1fp_x64_ForNXP%5Clib%5Cthumb2%22%20-cpu%3Dcortexm7%20-thumb%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎08-03-2026 02:55 AM
更新者:
