why am I getting a verify error when programming using PROG12Z.
S12user
Getting the following verify error:
'Verify error at address $0FFF0F. Byte in module is $00 and should be $01. Continye Verifying?'
Why am I getting this erorr?
and how do I correct it?
It seems that the LCD on the device does not initialize properly because of this.
lama
See may response in:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/MC9S12A128CFUE-after-programming-using-PROG...
However, as I wrote there, Prog12z is not our tool so if it automatically reprograms security byte and you application does not contain this byte in the same status then there can be incompatibility.
Ladislav
