value mask filter How to set "Receive cycle counter filter value" and "Receive cycle counter filter mask" ? I had seen "CYCCNT^MBCCFRn[CCFMSK] = MB
1,033 次查看
leidou
Thank you for your reply. This is my first time asking question in NXP Community. I chose the wrong options. It is not a i.MX Processors problem. It is about MC9S12XF512. I had seen the answers for "How to Calculate Cycle Counter Value/Mask ", but no one gave the answers. Someone even said " It's a freescale mystery...". I will be very grateful if you can help me.
Lei
943 次查看
dianabatrlova
Hi Lei,
I added here the received example from the application engineer.
Example: The application wants to receive a frame in every 4th cycle, start in cycle 1.
  1. The periodicity is configurable by the CCFMSK – cycle counter filtering mask
                CCFMSK = Perioda-1 = 4-1=3
  1. The start offset is done by configuring the CCFVAL – cycle counter filtering mask
                CCFVAL = in which cycle to start = 1
  1. We need to enable the cycle filtering by set the CCFE bit
Diana
