how to develop bootloader using LIN protocal based on AN4723-S12Z_BootLoader software
3,135 次查看
NoahXu
Dear support ,
 now i am developing bootloader for S12ZVML128 MCU.
 ia read through the AN4723 and find the SCI1 is used, if sci1 is not available but LIN is available, how can i modify the AN4723SW?
5 回复数
3,122 次查看
danielmartynek
Hello @NoahXu,
I'm not sure what you mean.
The LINPHY can be routed to SCI0 only.
There is such a bootlaoder already:
AN5389 S12Z MagniV LIN Bootloader
https://www.nxp.com/docs/en/application-note/AN5389.pdf
https://www.nxp.com/docs/en/application-note-software/AN5389SW.zip
3,083 次查看
NoahXu
Hi,Daniel
another problem during compile of this AN5328SW ,seems the stack size is set wrong for this demo.
how would you suggest to change?
Noah
3,049 次查看
danielmartynek
Hi Noah,
Indeed the compiled code is too big.
Have you tried increasing the size SHADOW_ROM_S and SHADOW_RAM_S sections:
You could also use a higher optimization level:
3,096 次查看
NoahXu
Hi, Danielmartynek
  thanks for reminder, this AN5389SW is what I need.
  when i try to use this SW, i found the PC application program is difficult to understand.
  how to use this S12Z_MagniV_Serial_Bootloader_Interface.jar ?
  should i develop some windows java application?
Noah
3,051 次查看
danielmartynek
Hi @NoahXu,
The S12Z_MagniV_Serial_Bootloader_Interface.jar interface is for the SCI bootloader.
For the LIN bootloader, you need a LIN master that would send the data
The master should send the S-record file data in frames of 8 bytes with the ID reserved for reception of data, as explained in AN5389.
