first code = problem (9s12c32)
4,055 次查看
bluemind
im a newbiem and this is my first code, so bear with me, the only thing it shal is to make a led blink. (running one a DF12-DIP40-R, on a DF12-DOCK40(www.evbplus.com))
im using CW! do it loock totally off....
do i need to set the pll to run prorgams on the chip. and if so, where can i find code there will work.
my problem is that i am missing examples/information in how to program in c. almost all i can find is in assamble, and i¨m not good at that. posserbil a good book to read on the subjekt woud be great..
1,765 次查看
kwik
Did you download Englers or Franks IDE's ? You find links at www.evbplus.com
When you do that you will find example projects in C .
An example project is even better than books.....
1,765 次查看
bluemind
found the problem...
but are there any book you woud recomand for a newbie.
