S12zvl “unintended” vs. “intentional” watchdog reset
857件の閲覧回数
charudattaingal
Hello Team,
we need to  discern unintended” vs. “intentional” watchdog reset.
we need to differentiate watchdog reset is occur due to no feeding/Servicing watchdog,when window is open.
OR
watchdog reset occur due to writing invalid pattern on watchdog register.
Please suggest.
Thanks You!
Charudatta
800件の閲覧回数
danielmartynek
Hello Charudatta,
You can use a flag variable at a specific address and then read it in startup code by a pointer before it gets reinitialized by the ZeroOut, CopyDown functions in the default CW startup code. Or you can place a variable to NO_INIT section as it was discussed here: How to avoid RAM cleaned in start up for S12ZVML
So that it doesn't get initialized.
