S12ZVL EEPROM emulation
2,697件の閲覧回数
eunsangcho
Does anyone know about EEPROM emulation for S12ZVL?
There's some problem and limitation to use PFLASH as EEPROM.
I only could find the document for Qorriva, but there's no sample code or driver.
https://www.nxp.com/docs/en/application-note/AN4868.pdf
Thank you.
2,480件の閲覧回数
danielmartynek
I’m afraid there is no such driver for MagniV MCUs.
There are drivers for S12C32/S12XS/S12P MCUs which do not have EEPROM.
AN2302 EEPROM Emulation for the MC9S12C32
AN2302SW
AN3961 EEPROM Emulation for the MC9S12XS and MC9S12P Families Using AN2302 as a Reference
AN3961SW
You might use the drivers as a reference.
Unfortunately, that’s all we have.
3 返答(返信)
2,480件の閲覧回数
danielmartynek
There is EEPROM (128 - 2048B) on S12ZVL.
Do you need to emulate additional EEPROM?
Daniel.
2,480件の閲覧回数
eunsangcho
Hi Daniel.
I'm using 12ZVL32F that has 128byte EEPROM.
It's not enough space to satisfy our specification .
To satisfy our specification, I need additional space.
But, there's limitation to use PFLASH as EEPROM as you know.
I found this similar solution to another device Qorivva.
And, I want to know if there's driver and documentation for the MagniV about EEPROM emulation.
Thank you.
2,481件の閲覧回数
danielmartynek
AN2302SW
AN3961SW
