After the master node send the frame (ID=0x3C: 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF), the slave node should go to sleep. But, I don't know the LIN bus got the frame (ID=0x3C: 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF).
Is there interface in the LIN Stack? I am using the FSL_LIN_2.x_STACK_Package_4.5.9, MCU is S12VR64.
Best regards.
