S12ZVCA19 array size
1,912 次查看
aaronlee
Our project use S12ZVCA19. We need create an array to save 30000 strings (each string =10 characters).
Is it can work? How to make sure the free space in memory?
Aaron
标记 (2)
1,778 次查看
aaronlee
Hi Daniel,
We use SD card to store. Thanks for your information. It's very useful.
BR, Aaron
4 回复数
1,778 次查看
aaronlee
Hi, Daniel,
uint32_t      array[30000];
Can I use that define in S12ZVCA19?
BTW, I have define a lot of variable, how to check the free space of variable?
Best Regard,
Aaron
1,778 次查看
danielmartynek
Hi Aaron,
The S12ZVCA19 MCU has 12KB of SRAM.
You can't use a 120KB variable.
Please check the linker file and the map file.
BR, Daniel
1,779 次查看
aaronlee
Hi Daniel,
BR, Aaron
1,778 次查看
danielmartynek
Hi Aaron,
I'm afraid you can't store 300KB on a 192KB Flash.
BR, Daniel
