How to soft restart the S12ZVC?
已解决
跳至解决方案
1,809 次查看
aaronlee
Contributor V
How to soft restart the S12ZVC? Not watch dog.
Best Regard,
Aaron
标签 (1)
标记 (1)
1 解答
1,698 次查看
danielmartynek
Hi Aaron,
The MCU has only the reset sources shows below.
There is no SW reset. Triggering COP is the recommended way.
You could use a GPIO connected to the reset pin to trigger the External pin RESET by driving the GPIO low.
BR, Daniel
在原帖中查看解决方案
2 回复数
1,699 次查看
danielmartynek
Hi Aaron,
BR, Daniel
1,698 次查看
aaronlee
Contributor V
Hi Daniel,
Thank you very much.
Aaron
