S12Z boot jump
S12Z boot jump
1,247件の閲覧回数
L_lh
Debugging the boot of S12Z, but there was a problem with the boot redirecting to the app and it couldn't be redirected. Can you help me check the problem. My steps: 1. Boot burn address 0xFFC000-0xFFFDFF 2. APP burning address 0xFE0200-0xFFBFFF 3. The program runs in the boot to enable CAN_ IBS_ Control. u8con=2 to execute the jump app operation 4. The resulting program does not jump and runs directly into while (1) The attachment contains some code for the APP and boot project, and I have removed some other unrelated code
1,229件の閲覧回数
lama
I'd like to suggest you to compare the code with this one....
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/Simple-Serial-Bootloader-for-S12Z-AN-draft/...
Ladsialv
