S12Z MagniV Serial Bootloader Interface
simonliu
    I want to test bootloader for ZVL,How can I get the "S12Z MagniV Serial Bootloader Interface" sofetware?
dianabatrlova
I would like to recommend you to use the newer application note AN12086 - Simple Serial Bootloader for S12Z
https://www.nxp.com/docs/en/application-note/AN12086.pdf
The software of AN12086:
https://www.nxp.com/docs/en/application-note-software/AN12086SW.ZIP
However, the software of the AN4723 can be downloaded here: http://www.nxp.com/files/microcontrollers/doc/app_note/AN4723_SW.zip
I hope it helps.
Diana
SW_Park
Hello.
Please check the path to the S12Z MagniV Serial Bootloader Interface Tool, not the software.
